flashplayer6?
jackLFLB
Liked in: 8 posts
flashplayer6?
by jackLFLB » Sun Mar 14, 2010 6:41 pm
Hi!
When rendering my tour, the swf opens hitself in a flashplayer6, and appears black. I dont understand where it comes from...
Do someone know the problem? I only have the version 10 n my PC.
:rolleyes:
by mediavets » Sun Mar 14, 2010 7:05 pm
Are you using the latest version V1.1 beta 7?:
http://www.autopano.net/forum/t7116-apt-v1.1-beta
jackLFLB
Liked in: 8 posts
by jackLFLB » Mon Mar 15, 2010 3:05 pm
I have the 1.0.6.0 version, bought in last january. It is the first time that mt swf created in APT opens itself in the flashplayer6
by mediavets » Mon Mar 15, 2010 3:11 pm
jackLFLB wrote:I have the 1.0.6.0 version, bought in last january. It is the first time that mt swf created in APT opens itself in the flashplayer6
May I still suggest you try use the latest V1.1 beta 7 and see if that resolves the issue?
jackLFLB
Liked in: 8 posts
by jackLFLB » Mon Mar 15, 2010 4:29 pm
of course you may Andrew, it is so kind of you to answer! But I was thinking about the fact that of course I downloaded Flashplayer 10, but my version of Flash (Adobe) installed on my PC is the 6 one. Is there a link in what occurs?
jackLFLB
Liked in: 8 posts
by jackLFLB » Mon Mar 15, 2010 4:56 pm
Well, I did what you suggested. The problem remains exactly the same. I cant read the file in the systematically flashplayer6 opening the swf, but it is displayed in the html document when I open it... But this new version offers some new pleasant possibilities!!
Jack
