101 question ? nadir patch image format ? file size ? please help.
sjosyula
by sjosyula » Thu Mar 11, 2010 1:51 pm
I initially made a 360 X180 degree panorama, converted it to 2:1 and then I am trying to add the nadir patch. But, it is not working for some reason.
I made the nadir patch and exported it as .png and the file size is around 50 kb. The nadir patch shows up in the 3d preview editor but not in the final .swf file.
I have no idea, why it is not showing up in the final file. Please help me.
( im using mac osx 10.5)
thanks,
Sandeep.
manuel rosario
by manuel rosario » Fri Mar 12, 2010 3:34 pm
I am using macbook pro with os 10.6.2 and APT 1.1 beta 7. I tried to put a nadir (png, 110 kb) at .20 scale, on my 360x180 pano and is working and is showing on the html or swf. I entered my nadir patch tru the panorama property table. fyi.
cheers
manny
Canon EOS20d, 50d, sigma 12-24, samyang 8mm FE, 4GB ram, 2.53 GHz MacBook Pro 13.3 Snow 10.6.8, Panosaurus, Nodal Ninja NN3II, AutopanoGiga+PTP, KRPano Unlimited, Photomatix4, onOne PhototoolsPro 2.6 and Perfect Resize 7, Noiseware Pro, Topaz Suite, PS CS5.
sjosyula
by sjosyula » Sun Mar 14, 2010 1:42 am
thanks very much. I observed that the nadir patch is working properly either at 0.20 scale or 1.00 scale. anything inbetween is not working.
by mediavets » Sun Mar 14, 2010 6:47 am
sjosyula wrote:thanks very much. I observed that the nadir patch is working properly either at 0.20 scale or 1.00 scale. anything inbetween is not working.
Did you post a bug report here?:
http://www.autopano.net/forum/f23-autopano-tour-bug-discussion
Adrien F
by Adrien F » Mon Mar 15, 2010 12:00 pm
sjosyula wrote:I observed that the nadir patch is working properly either at 0.20 scale or 1.00 scale. anything inbetween is not working.
A similar bug was reporteed for the 1.0.6 version, the correction will be released in next update. But the weird thing is it works for 1.00 scale, which version do you use?
cube face width?
nadir pach size?
thanks
