Error - deleto hotspot
Marknot
by Marknot » Tue Mar 09, 2010 1:17 pm
Hello. i've problem on my project, i just open it and trying to delete a simple hotspot and the program crash... :rolleyes: so HELP!
by mediavets » Tue Mar 09, 2010 1:30 pm
Marknot wrote:Hello. i've problem on my project, i just open it and trying to delete a simple hotspot and the program crash... :rolleyes: so HELP!
Hmmmm..I have never had this problem.
Are you usng the latest version V1.1. beta 7?:
http://www.autopano.net/forum/t7116-apt-v1.1-beta
by klausesser » Tue Mar 09, 2010 1:49 pm
How exactly did you try to delete the hotspot?
Marknot
by Marknot » Tue Mar 09, 2010 1:57 pm
Thanks for the answer, i have simply delete from the (map -image-), the only resolution was to delete all the map and making from the beginning all the hotspot....
So i would like to know why if i make a click on arrow (signs) on a pano the hotspot in the map is not being update and he think that i'm in the old pano...that's very bad thing.. i need to have only spot on the map!? there is no synchronism from the spot in the map and the arrow guide in the pano!? the same happened if i use the thumbnails...if i click on a pano the map look and the old pano...
Marknot
I'm using that one...
by mediavets » Tue Mar 09, 2010 2:10 pm
Marknot wrote:So i would like to know why if i make a click on arrow (signs) on a pano the hotspot in the map is not being update and he think that i'm in the old pano...that's very bad thing.. i need to have only spot on the map!? there is no synchronism from the spot in the map and the arrow guide in the pano!? the same happened if i use the thumbnails...if i click on a pano the map look and the old pano...
IIRC that issue has already been acknowledged and Adrien said it will be fixed in the next beta.
by klausesser » Tue Mar 09, 2010 2:56 pm
Marknot wrote:Thanks for the answer, i have simply delete from the (map -image-), the only resolution was to delete all the map and making from the beginning all the hotspot....
I simply don´t understand what you mean exactly.
Deleting a hotspot in APT is very easy: you just go into the window at the left downside of the editor- that´s the "Hotspot Editor" - press "ctrl" and click onto the spot. Then you´ll be asked to delete or not. That´s all.
I also don´t understand what you mean with the thumbs - i suggest to read any tutorial you can find about APT and i suggest to learn about KRPano . . . for which APT is just a GUI.
You set the thumbs in "Project Properties" - you can choose a position and a size. It takes the pictures from the previews in your data-folder.
Maybe it doesn´t work when you render the tour as "embed all files" or "embed xml". To use the thumbs i guess - i never use "embed" - you have to deselect "embed" because the thumbs come from the previews. And these are in the "xxdata" folder - which you don´t have with embed: here everything is in ONE .swf file.
A problem still is the lack of a good and understandable description for APT.
by gkaefer » Tue Mar 09, 2010 4:26 pm
Klaus,
I think he's talking about the hotspots shown on the map inside the pano and not talking about normal hotspots...
by klausesser » Tue Mar 09, 2010 4:52 pm
gkaefer wrote:Klaus,
Map inside the pano? I see . . . wasn´t clear to me :cool:
by mediavets » Tue Mar 09, 2010 4:58 pm
Ah... you didn't say that you were trying to delete a hotspot from a Map image in your initial post.
I can confirm that I also had the APT program lock up when trying to delete a hotspot from a Map image.
Definitely a bug I think.
Marknot
by Marknot » Tue Mar 09, 2010 5:21 pm
Thanks, i was thinking that was only my problem and sorry for my english... ;)
by mediavets » Tue Mar 09, 2010 5:24 pm
Marknot wrote:
mediavets wrote:Ah... you didn't say that you were trying to delete a hotspot from a Map image in your initial post.
I think your English is fine.
I have reported the issue as a bug:
http://www.autopano.net/forum/t8461-apt-v1.1-beta7-deleting-hotspots-from-map-image
by klausesser » Tue Mar 09, 2010 5:52 pm
Better report this bug also in the KRPano forum!
Maybe they have a solution.
