"Wrong Krpano version - 1.0.7 needed"
Vitali
by Vitali » Sun Mar 07, 2010 3:37 pm
Trying Autopano Tour Beta (I have Krpano unlimited license)
:o I am trying to create custom XML templates and it works fine except one little thing always I have error message
"wrong krpano version - 1.0.7 needed" but I can see combobox itself (in case of using combobox.swf) etc
Any Idea what's happening? (I have tried different plugins 1.0.7 and beta version - having same result. even two plugins: editor.swf and options.swf, that come with APT show same error )
Any help will be much appreciated
Adrien F
by Adrien F » Mon Mar 08, 2010 10:18 am
Your message indicates your plugin requires the 1.0.7 version of krpano, and the version used in APT beta is 1.0.8 (beta 8). To avoid problems, always use the plugin version corresponding to the krpano player version.
The combo box is available from the user interface in beta versions of APT and works well, so maybe try to export with this option instead, and eventually reuse the exported combo box plugin.
BTW which APT beta version do you use?
PS: The next APT beta version will include the latest krpano player and plugins.
by klausesser » Tue Mar 09, 2010 5:54 pm
better report this in the KRPano forum also!
Vitali
by Vitali » Wed Mar 10, 2010 12:06 pm
Thank you.
Simple reinstall solved the problem
