directional sound on apt beta7?
wlidha
by wlidha » Wed Mar 03, 2010 9:59 pm
i noticed that in apt 1.1 beta7 we can add a hotspot wihch link to an mp3; when clicked, the sound play on directional mode.
is there a method to add directional sound which play when the pano begin?
by mediavets » Wed Mar 03, 2010 10:06 pm
wlidha wrote:i noticed that in apt 1.1 beta7 we can add a hotspot wihch link to an mp3; when clicked, the sound play on directional mode.
I don't think so - but this is exactly the sort of thing I had in mind when I suggested some time back that it would be good to have a specific audio/sound type of 'hotspot'. It could act like a normal hotspot and play when clicked upon with a choice of image to represnet the hotspot or it could operate in a 'hidden mode' whereby nothing woulkd be diplayed to the person viewing but the author could place the directional sound and specifiy that it should play on pano load.
wlidha
by wlidha » Fri Mar 05, 2010 4:23 pm
mediavets wrote:it would be good to have a specific audio/sound type of 'hotspot'.
given that the directional sound seems to be already supported by APP, i think (hope :rolleyes:) that kolor team will add it as a full functionality. may be they can add "sound file" as a possible choice on hotspot's display options such as they did for flash video files
by klausesser » Fri Mar 05, 2010 4:36 pm
You have to use the KRPano tools to work with directional sound.
by mediavets » Fri Mar 05, 2010 4:39 pm
We know....but it should IMO be made available from the GUI.
MaGue
by MaGue » Fri Mar 05, 2010 9:24 pm
Right Andrew. I also think so.
and some other things like round Jumpgates
best,
Martin
by mediavets » Fri Mar 05, 2010 10:08 pm
MaGue wrote:and some other things like round Jumpgates
I think this perhaps got 'lost in translation' - what's a jumpgate?
wlidha
by wlidha » Fri Mar 05, 2010 11:20 pm
klausesser wrote:You have to use the KRPano tools to work with directional sound.
i purchased autopanogiga to avoid handling of xml ;)
Autopano Pro's features
- Exclusive virtual tour creation system, to create complete virtual tours in Flash format without programming skills
by klausesser » Sat Mar 06, 2010 12:22 am
wlidha wrote:i purchased autopanogiga to avoid handling of xml ;)
Yes - me too! But you´ll have to . . . . :cool:
I guess it´s a matter of time and APT as a GUI to KRPano will be perfected.
MaGue
by MaGue » Sun Mar 07, 2010 11:02 pm
You can Do Hotspots in Points, polygons and Frames. But not in Circles.
And sometimes a round Hotspot would be nice.
best,
Martin
