FOV error
marquee
FOV error
by marquee » Wed Mar 03, 2010 12:42 pm
i've been setting the max and min values in the 3D editor view, usually it corresponds to the view parameters tab but its been playing tricks on me all day.
The max setting in the view pane adjusts the min settings in the parameters and vice versa.
This is a definite bug.
I've recently updated to 64 bit window 7.
Could this be a 64 bit bug because it worked fine all along in xp pro
could someone please rectify this issue.
thanks
marquee
by mediavets » Wed Mar 03, 2010 1:29 pm
marquee wrote:i've been setting the max and min values in the 3D editor view, usually it corresponds to the view parameters tab but its been playing tricks on me all day.
thanks
marquee
Is this just not down to the difference betwen max. FOV and max. zoom?
Max. zoom is of course min. FOV and vice versa.
I agree it can be confusing.
