Map start on high resolution
Marknot
by Marknot » Wed Mar 03, 2010 9:55 am
Hello, i would like to start the map in a "little size" when the virtual tour is starting, after click it can be resized. It's that possible?!
Thanks in advance.
Adrien F
by Adrien F » Wed Mar 03, 2010 2:23 pm
right now it is only possible by editing the xml :
Original line:
<plugin name="map" url="testdata/map/map.png" keep="true" align="lefttop" x="10" y="10" width="150" height="prop" handcursor="false" onclick="action(closemap);"/>
Modified line:
<plugin name="map" url="testdata/map/map.png" keep="true" align="lefttop" x="10" y="10" width="40" height="prop" handcursor="false" onclick="action(openMap);"/>
Of course you put the values you want for the width of the plugin.
Marknot
by Marknot » Wed Mar 03, 2010 3:54 pm
Well i just need to create that folder with the image and use that code or i can add to the xml template and i will delete the map every time. ok i will try it. thanks a lot;)
by mediavets » Wed Mar 03, 2010 4:34 pm
Adrien F wrote:Hello,
Would be nice to offer it as a parameter/option in the GUI don't you think?
