KRPano and APP tour. How do they work together????
Vitali
by Vitali » Sat Feb 27, 2010 8:20 pm
Hi all,
I have downloaded beta versions of KRPano and APP separatelly. Started with KrPano first...find it amazing. No problems with XML whatsoever
But if KRPano unlimited license comes with APP tour, how all the plugins of KRPano will work with APP tour??? Or they will not and APP tour has a limited set of plugins?
Or I can add them when I need them?
Sombody please explain this to me...
vincen
Kolor Certified Trainer
Likes: 14 posts
Liked in: 3 posts
by vincen » Sun Feb 28, 2010 7:03 am
In fact APT handles some of the plugins of KRPano but not all. For example Google Maps plugin is not yet avalaible in APT. You have no way to add management of a plugin in APT, but you can nevertheless add by hand some functions and plugins in virtual tours generated by APT by editing XML files generated :)
Vincèn
Blog: http://www.skivr.com
My shop for panoramic photography: http://magasin.skivr.com
Vitali
by Vitali » Sun Feb 28, 2010 1:50 pm
Thank you.
:P Well....there is nothing I can do then....old good manual coding forever!!!
vincen
Likes: 14 posts
Liked in: 3 posts
by vincen » Sun Feb 28, 2010 1:53 pm
Vitali wrote:Thank you.
Yep but you can avoid wasting time with basic coding all done by APT, just add your additional code :) You are able to do some templates that APT can use for each tour you build with it :D
Vincèn
