Problem with IE
flash-point
Problem with IE
by flash-point » Wed Feb 24, 2010 6:55 pm
Hi There!
We have been trying out Autopano Tour V1 beta 7;the tours are posted on our site and we cant open them when using Inetrnet Explorer.The problem does not exist on other browsers.
Link to our website:
http://www.flash-point.pl/en/realizacje.html
Thanx for your help
Martin
Adrien F
by Adrien F » Thu Feb 25, 2010 9:24 am
I just tried it on IE7 Chrome and Firefox 3.5.6 and all work fine.
Could you tell us what exactly goes wrong?
(I like the first place btw!)
flash-point
by flash-point » Thu Feb 25, 2010 10:55 am
thanks for your reply.The problem appears when i use APT V1 beta 7.
We asked the question on KrPANO forum as well ,and for some users it's workin' fine,but not for all.
Basiclly what happens is,when i try to load the tour in IE 8,the only what loads is a black screen with the arrows.And i cant do anything with it.
Check out the print screen below
Regards
Martin
by mediavets » Thu Feb 25, 2010 11:09 am
flash-point wrote:Hi,
Regards
Martin
No problem here - WinXP Pro 32-bit with SP3, IE8 - see screenshot. Might it depend on RAM spec on individual PCs?:
by gkaefer » Thu Feb 25, 2010 2:21 pm
win7 ultimate & IE8 no problem here...
did you check the macromedia flash settings...
inside (black) pano -> right mousclick -> settings -> advanced (redirect to macromedia website) -> global privacy settings panel)
