Using Standard images to give more info
cptpicard
by cptpicard » Tue Feb 16, 2010 11:47 am
I have several panoramics that I'm using for a complete virtual tour. I wondered whether it was possible to have normal NON 3D images which you can use to provide more information about a particular object. For example, I have a VT of the inside of a building. I would like to create hotspots for particular objects which link to a normal image. When you click on this hotspot, it would zoom into the image and give you a detailed description of it. If this is not currently possible using this software, I think it would be a really useful feature.
Is there any way I can do this? Or would I need to purchase some other software?
Thanks in advance for your help.
Cpt.
by klausesser » Tue Feb 16, 2010 5:26 pm
cptpicard wrote:Is there any way I can do this? Or would I need to purchase some other software?
You can do it using APT in combination with the KRPano tools for fine-tuning/editing what APT spits out.
You need to have equirectangular images to feed to APT.
cptpicard
by cptpicard » Tue Feb 16, 2010 6:49 pm
Hi Klaus - is that something I have to pay for as an extra. I've currently got just the APT without the unlimited license version - Not sure the difference actually!
by mediavets » Tue Feb 16, 2010 8:07 pm
cptpicard wrote:I have several panoramics that I'm using for a complete virtual tour. I wondered whether it was possible to have normal NON 3D images which you can use to provide more information about a particular object. For example, I have a VT of the inside of a building. I would like to create hotspots for particular objects which link to a normal image. When you click on this hotspot, it would zoom into the image and give you a detailed description of it. If this is not currently possible using this software, I think it would be a really useful feature.
Cpt.
I agree a specific function/feature exactly like that would be nice - I'd call it an Information hotspot type.
In the meantime you may be able to get something close to that by defining the target of a point hotspot link as 'HTML' or 'Object'.
Try it and see whether this may be 'good enough' for now.
BTW I assume you are using the latest beta of APT - V1.1 beta 7?:
http://www.autopano.net/forum/t7116-apt-v1.1-beta
by mediavets » Tue Feb 16, 2010 8:11 pm
cptpicard wrote:Hi Klaus - is that something I have to pay for as an extra. I've currently got just the APT without the unlimited license version - Not sure the difference actually!
You need a krpano unlimited domains license to externalise the XML APT generates for futher hand editing.
IMO, APT is really quite limited without a krpano unlimited domains license.
cptpicard
by cptpicard » Tue Feb 16, 2010 8:28 pm
Mediavets - I wasn't, but now I've downloaded it and this works ok. I think I may need to also purchase the unlimited license as you mentioned to have greater control.
Thanks for your help.
Cpt.
