APT Beta dev plan
Adrien F
APT Beta dev plan
by Adrien F » Fri Feb 12, 2010 10:22 am
Main features under development for...
Beta 8:
[uli]Giga support: reading large image files (jpg, kro, psb), exporting full resolution[/uli]
[uli]Bug correction[/uli]
[uli]Comments in generated xml code[/uli]
Adrien F
by Adrien F » Thu Jun 24, 2010 3:50 pm
So the beta 9 version (formerly known as beta8) came out today.
We don't plan to add new features to the 1.1 beta branch in near future, except bug correction.
However we will focus on a new branch called 1.5 where the separation of APT in two versions will take place.
In order not to mix people with our product registration and the krpano registration, and to provide the software versions that correspond to everyone, we will release :
* a standard version
* a pro version
Adrien F
by Adrien F » Mon Aug 23, 2010 4:27 pm
Beta 10 came out today.
Plans for beta 11 are still bug fixes (those which were not fixed in beta 10).
"APT 1.5" is still on its way.
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Mon Aug 23, 2010 4:28 pm
Adrien F wrote:Beta 10 came out today.
What are changes in that beta 10 ? just bug fixes ?
Thanks,
Vincèn
Blog: http://www.skivr.com
by mediavets » Mon Aug 23, 2010 4:35 pm
Adrien F wrote:So the beta 9 version (formerly known as beta8) came out today.
* a pro version
Are you yet in a position to be able to explain more about the difference between the proposed Standard version and Pro version?
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Mon Aug 23, 2010 4:44 pm
mediavets wrote:Are you yet in a position to be able to explain more about the difference between the proposed Standard version and Pro version?
It was indicated during meeting that principal difference between both versions will be capability to use your own themes for web interface in Pro version, Std version will only have a fixed set of themes ;)
Vincèn
JohnM
by JohnM » Sat Sep 25, 2010 10:53 am
Any roadmap for theme/xml features ?
