IO Error
IFlyGC
IO Error
by IFlyGC » Tue Jan 26, 2010 8:18 pm
Hello All,
I did a search on here but was unable to find an answer that worked for me, so I'm hoping someone can assist.
I am using Autopano Tour for the first time and am trying to create HTML hotspots. In a nutshell, the pano is on an HTML page with an iFrame next to it. When you click on a hotspot, it should populate the iFrame with an HTML page, simple enough, right?
So, in my hotspot I have the following code in the HTML box (athough it fails even with much more basic): <a href="http://www.myurl.com/page.html" target="myIFrame">Popup</a>.
I export the flash, upload everything to my host and upon loading I get the following error where the tour should be (see image below).
Just FYI, it also gives me the same error regardless of what I put in the HTML box. A simple "Hello." causes the same error message.
Any ideas how to fix that? It's driving me crazy!
Thanks,
Dave
by mediavets » Tue Jan 26, 2010 8:39 pm
I think your syntax may be incorrect, see:
http://www.krpano.com/docu/actions/#openurl
Maybe some of the XML coding gurus on the krpano forum could help if that's not the problem:
http://www.krpano.com/forum/wbb/index.php?l=2
IFlyGC
by IFlyGC » Tue Jan 26, 2010 9:20 pm
Andrew,
Thanks for your input. I'm not sure why, but if I manually edit the .xml file to get the desired results everything works like a charm. I guess it's either a bug in the Tour program, or operator error.
Either way, thanks for sending me in a direction that lead to a good result!
Cheers,
Dave
