Start Postion / Destination View work around anyone?
Zigmo
by Zigmo » Sat Jan 23, 2010 7:40 am
I am looking to eliminate the "Start Position" from my tour. I would like the Destination View to be the only point. The problem occurs when 2 or more panos point to a single pano. Naturally I would like all of them to have a different "Destination View" based on the angle of entry. This gives a more natural feel. My problem is that it will always start at the "Destination View" and pan to the "Start Position". I can always cheat this on one of the "Destination View" point by making it share the "Start Position". But for the others I'm stuck with this awkward panning. So does anyone know how to eliminate this problem?
by mediavets » Sat Jan 23, 2010 10:02 am
Zigmo wrote:I am looking to eliminate the "Start Position" from my tour. I would like the Destination View to be the only point. The problem occurs when 2 or more panos point to a single pano. Naturally I would like all of them to have a different "Destination View" based on the angle of entry. This gives a more natural feel. My problem is that it will always start at the "Destination View" and pan to the "Start Position". I can always cheat this on one of the "Destination View" point by making it share the "Start Position". But for the others I'm stuck with this awkward panning. So does anyone know how to eliminate this problem?
Welcome to the forum.
I think you are not using the latest version of Autopano Tour (APT).
Find the latest version APT V1.1 beta 6 here:
http://www.autopano.net/forum/p51122-2009-09-07-11-54-52#p51122
This has the concept of Spot View (what was formerly termed Destination View I think).
More importantly there are now several different types of transition available from hotspots.
So to achieve the effect you seek I think you want to use either LoadSpotView or PanoViewToSpotView.
Zigmo
by Zigmo » Sat Jan 23, 2010 5:24 pm
That works perfect. That just rendered me purchasing the Full KRpano Licence useless.
by mediavets » Sat Jan 23, 2010 6:21 pm
Zigmo wrote:That works perfect. That just rendered me purchasing the Full KRpano Licence useless.
I think you will come to value having the full krpano licence; there are several key features of APT that are disabled without such a license; for example, the max. cube face size is very limited and you have no access to the XML generated by APT without it.
