"calling" an URL from the tour
by klausesser » Wed Jan 20, 2010 5:57 pm
Hi!
Here - http://www.360impressions.de/Ackermann.html - i tried to link a movie in the "Werkstatt" node.
here´s the xml file:
<krpano version="1.0.8">
    <events onloadcomplete="playbackgroundsound(none);"/>
    <panoview h="-159.68" v="-1.3" fov="70"/>
    <view fisheye="0" limitview="lookat" vlookatmin="-90" vlookatmax="90" fovmin="20" fovmax="90" fov="70" hlookat="-159.68" vlookat="-1.3"/>
    <progress showload="none" showwait="none"/>
    <preview url="Ackermanndata/Ackermann4/preview.jpg"/>
    <image type="CUBE" multires="true" tilesize="398" baseindex="0">
        <level tiledimagewidth="3184" tiledimageheight="3184">
            <left url="Ackermanndata/Ackermann4/3/3/%v_%u.jpg"/>
            <front url="Ackermanndata/Ackermann4/0/3/%v_%u.jpg"/>
            <right url="Ackermanndata/Ackermann4/1/3/%v_%u.jpg"/>
            <back url="Ackermanndata/Ackermann4/2/3/%v_%u.jpg"/>
            <up url="Ackermanndata/Ackermann4/4/3/%v_%u.jpg"/>
            <down url="Ackermanndata/Ackermann4/5/3/%v_%u.jpg"/>
        </level>
        <level tiledimagewidth="1592" tiledimageheight="1592">
            <left url="Ackermanndata/Ackermann4/3/2/%v_%u.jpg"/>
            <front url="Ackermanndata/Ackermann4/0/2/%v_%u.jpg"/>
            <right url="Ackermanndata/Ackermann4/1/2/%v_%u.jpg"/>
            <back url="Ackermanndata/Ackermann4/2/2/%v_%u.jpg"/>
            <up url="Ackermanndata/Ackermann4/4/2/%v_%u.jpg"/>
            <down url="Ackermanndata/Ackermann4/5/2/%v_%u.jpg"/>
        </level>
        <level tiledimagewidth="796" tiledimageheight="796">
            <left url="Ackermanndata/Ackermann4/3/1/%v_%u.jpg"/>
            <front url="Ackermanndata/Ackermann4/0/1/%v_%u.jpg"/>
            <right url="Ackermanndata/Ackermann4/1/1/%v_%u.jpg"/>
            <back url="Ackermanndata/Ackermann4/2/1/%v_%u.jpg"/>
            <up url="Ackermanndata/Ackermann4/4/1/%v_%u.jpg"/>
            <down url="Ackermanndata/Ackermann4/5/1/%v_%u.jpg"/>
        </level>
        <level tiledimagewidth="398" tiledimageheight="398">
            <left url="Ackermanndata/Ackermann4/3/0/%v_%u.jpg"/>
            <front url="Ackermanndata/Ackermann4/0/0/%v_%u.jpg"/>
            <right url="Ackermanndata/Ackermann4/1/0/%v_%u.jpg"/>
            <back url="Ackermanndata/Ackermann4/2/0/%v_%u.jpg"/>
            <up url="Ackermanndata/Ackermann4/4/0/%v_%u.jpg"/>
            <down url="Ackermanndata/Ackermann4/5/0/%v_%u.jpg"/>
        </level>
    </image>
    <hotspot name="spot0" hview="-0.56" vview="0.39" fovview="30" hcenter="136.823" vcenter="3.6" onclick="loadpano(Ackermann5.xml,null,null,BLEND(3));lookat(get(hview),get(vview),get(fovview));wait(blend);lookto(get(panoview.h),get(panoview.v),get(panoview.fov),smooth(100,5,50));" url="Ackermanndata/graphics/spots/spot0.swf" onhover="showtext(au√üen vor Werkstatt);" ath="496.823" atv="3.6"/>
    <hotspot name="spot1" onclick="openurl(http://www.360impressions.de/Ackerm_kompl.mov);" url="Ackermanndata/graphics/spots/spot0.swf" onhover="showtext(Movie);" ath="234.617" atv="20"/>
</krpano>
any idea?
by mediavets » Wed Jan 20, 2010 6:07 pm
This is what I see - do you get this too?:
by klausesser » Wed Jan 20, 2010 6:22 pm
mediavets wrote:This is what I see - do you get this too?:
yes - i get this too . . but i don´t know why. The link i set goes to: http://www.360impressions.de/Ackerm_kompl.mov
and this movie is in the same folder like all the tour´s parts.
P.S.: this bullshitting, crabby flash-player suggests to allow me to set the security settings - after i did it doesn´t use the settings and when i reopen the settings they´re like before.
P.S.: movie works now :cool:
JohnM
by JohnM » Wed Jan 20, 2010 11:47 pm
Is this when viewing online or local ? If its local then maybe its a flash security setting. Its working in your first example when I viewed it online.
by klausesser » Thu Jan 21, 2010 2:16 pm
JohnM wrote:Is this when viewing online or local ? If its local then maybe its a flash security setting. Its working in your first example when I viewed it online.
Yep - it´s a crabby Flash item . . . but it doesn´t let me set it for local playing . . .
JohnM
by JohnM » Thu Jan 21, 2010 7:09 pm
by klausesser » Thu Jan 21, 2010 7:26 pm
JohnM wrote:Maybe it will help to change your Flash security settings ?
http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager04.html
Yeah, man - i tried it for hours: thy aren´s saved. No way to keep the new settings. (Mac, Safari, Snow Leopard).
by gkaefer » Thu Jan 21, 2010 10:20 pm
I had not the same flash issues. pano itself was not displayed in my case (and also win7 in my case no mac...). Security settings from flash should solve it, and I could set it but problem was still there... even normal uninstall & redownload from adobe page did not solve it. Finally I found the dedicated uninstaller from adobe... after uninstalling this way & reboot of my win7 and finally download & install from flash finally again did solve it.
I used this uninstaller:
http://kb2.adobe.com/cps/141/tn_14157.html
Liebe Gruesse,
by klausesser » Fri Jan 22, 2010 1:26 am
Hi Georg!
Danke! Werd ich mal versuchen - wà¤r ja gelacht . . . :cool:
GruàŸ, Klaus
