Beta 6 no full screen on web.
Marv
by Marv » Tue Jan 19, 2010 8:02 pm
Settings:
Project Properties:
No menu or thumbnails.
Interface tab/Template: fullscreen.xml.
Export tab/Embed all data: unchecked
Export tab/Compute pictures: Checked
Export tab/HTML Template: simpleWithFullScreen.html
Render and plays full screen option on local desktop, but not full screen option from website. http://www.hsphotoservices.com/panorama.htm (see 4th or bottom pano).
What did I do wrong?
Marv.
Marv...
Nikon D700, Nikor 10.5mm DX (Shaved), Nikor 12-24mm DX, Modified Nodal NN180, Home made Nodal Ninja NN5 type Pano head, Really Right Stuff Plate & Clamps, Windows XP.
fotojehle
by fotojehle » Tue Jan 19, 2010 10:37 pm
Got the same problem with 1.0.6 in a iframe, Fullscreen can be activated with right-click, then the buttons appear normally.
Marv
by Marv » Tue Jan 19, 2010 11:45 pm
Hummm. I would like more comment on this as the right-click feature is turned off on the whole website in an attempt to prevent downloading of other photography on the site.
If the right-click thing is the problem then I think I'll have to create another site just for Panos.
Comments please.
Thanks Marv.
Marv...
by mediavets » Wed Jan 20, 2010 12:01 am
Marv wrote:Settings:
Project Properties:
Marv.
Did you compare the code used to display the panos on local desktop and the web site.
I think it may be very different.
Marv
by Marv » Wed Jan 20, 2010 12:30 am
[I think it may be very different.]
No I did not.
How do I do that?
Why would it be different? If it is different can I use the same code for the web as the desktop?
Marv...
by mediavets » Wed Jan 20, 2010 12:34 am
Marv wrote:[I think it may be very different.]
No I did not.
How do I do that?
Do you use a third party to develop the web site?
If so have him/her compare the simple HTML code generated by APT with the code that's used on the Web site.
Marv
by Marv » Wed Jan 20, 2010 2:03 am
Andrew, thanks. Good Idea... but, I remembered this was a Beta, so I reloaded the project file and re-rendered, and it works fine.
Marv.
Marv...
