I get 370 no virtual 360
Marv
by Marv » Sun Jan 17, 2010 6:05 am
Every so once in a while I get a panorama thats a 380, not a 360 that I can turn into a virtual continual panorama. It stops at the start and end images.
Back in pre-AP & APT I shot on a regular tripod 5 panoramas... all with 30-40% overlap and a nice even flat road in the foreground. 4 are just fine, but the 5th one with about 20-30% overlap at the start and end, appearently will not stich at that seam.
What's up? Can I force it?
Marv...
Nikon D700, Nikor 10.5mm DX (Shaved), Nikor 12-24mm DX, Modified Nodal NN180, Home made Nodal Ninja NN5 type Pano head, Really Right Stuff Plate & Clamps, Windows XP.
by mediavets » Sun Jan 17, 2010 2:30 pm
If you put the image set on-line somewhere (preferably as a ZIP file) I will be happy to download it and take a look.
Judy-A
by Judy-A » Sun Jan 17, 2010 5:48 pm
In the Control Point Editor Ctrl-click to select the two end images, so one image shows in each window. Marquee the areas they have in common and click the 'add control points' icon.
http://www.autopano.net/wiki-en/action/view/Control_Points_Editor#Add_Control_Points
Now you must optimize, preferably in stages. The ‘Adjust lens distortion’ setting will fit the pano perfectly within the 360˚ sphere.
http://www.autopano.net/wiki-en/action/view/Control_Points_Editor#Optimization
Marv
by Marv » Sun Jan 17, 2010 5:56 pm
Thanks Andrew, do you know a good secure site? If not I'll have my own upload/download thing built into my new website in a few days.
I found a fix, but I would still like to know why it did not work. By shear luck/accident, I shot my start point image as also my last image. So I simply used images 1841-1849 instead of 1840-1848. I don't know why but it worked perfect, but I would like to know why the 1840-1848 did not, if your game. I was lucky I shot the extra safety frame, I normally do not do that.
I had this happen once before when I shot in a huge warehouse and there was this huge black drape curtain that I started my shot with (my start point mistake).
Marv...
Marv
by Marv » Sun Jan 17, 2010 7:59 pm
Hi Judy,
Thanks, that fixed an alignment problem I had but it did not resolve the stiching issue. Basicly it took my first and last image and left the overlap on the ends and refused to seam the overlap to complete the virtual.
BTW this is a part of a set of 5 360's (1 is a 270) of ground zero devestation of Katrina/9th ward a block apart. I'll post the link Mon or Tue.
Marv...
