Problem
Problem
by klausesser » Mon Jan 11, 2010 6:49 am
Making a tour with APT i have a problem the the last node: it´s a planar image which should start at a narrow angle and end with showing the whole picture.
I set "spot view" and "default view" as usual to define start and end for the movement in transition.
Here´s the tour - watch the behavior of the last node:
http://www.360impressions.de/k21.html
i posted the xml files of the last two nodes (K2112.xml and k2115.xml) here:
http://krpano.com/forum/wbb/index.php?page=Thread&postID=10758#post10758
start-/spotview:
panoview/default view:
It´s a plane view - no cubic. It´s about 14000px wide and i set the cuttingsize to 512.
Any clue?
Stuart75016
by Stuart75016 » Wed Jan 13, 2010 7:07 am
I think the transition is aviable only combining with a hotspot ("spot view" to ...)
I don't know if there is a way to get the same effect of transition with a single view...
Best,
Laurent
by klausesser » Fri Jan 15, 2010 3:41 pm
Stuart75016 wrote:I think the transition is aviable only combining with a hotspot ("spot view" to ...)
Best,
Laurent
Hi Laurent!
There is a hotspot leading to this node - and there´s a hotspot in this node to lead to the following node.
But i solved the problem already with the help from Klaus (KR).
look here: http://www.360impressions.de/k21.html
by mediavets » Fri Jan 15, 2010 6:01 pm
klausesser wrote:But i solved the problem already with the help from Klaus (KR).
look here: http://www.360impressions.de/K21.html
I tried:
by klausesser » Fri Jan 15, 2010 6:22 pm
mediavets wrote:I tried:
try this one: http://www.klausesser.de/360impressions/k21.html
P.S.: it stalls a lot - seems to be a server-problem.
P.S.: the problem was "K" instead of "k" . . . . :rolleyes: using "k" it´s forewarded, using "K" it´s not. Or so . . . :cool:
by mediavets » Fri Jan 15, 2010 7:51 pm
Klaus,
The tour is looking good.
I think I found you 'haunting' the shop:
by klausesser » Fri Jan 15, 2010 10:36 pm
Klaus,
Let´s call it "Ghosting" . . . :cool::cool:
by mediavets » Fri Jan 15, 2010 11:21 pm
Klaus,
What's with the 'pistol' - is it an art work?
by klausesser » Sat Jan 16, 2010 12:59 pm
I tried to delete the image from my post - no success. How can i do it? I used the "delete" button.
Sorry - i had to delete the whole post.
Andrew: the pistol is an object created by Olaf Metzel. It´s part of the K21´s collection of contemporary art of the 21st century (therefore "k21").
http://www.bild.de/BILD/regional/duesseldorf/aktuell/2009/09/02/marion-ackermann/power-frau-mischt-unsere-kunst-szene-auf.html
by mediavets » Sat Jan 16, 2010 1:14 pm
klausesser wrote:Andrew: the pistol is an object created by Olaf Metzel. It´s part of the K21´s collection of contemporary art of the 21st century (therefore "k21").
I'm sure that in the UK such an object outdoors would either have been stolen or defaced with grafitti.
by klausesser » Sat Jan 16, 2010 4:27 pm
http://commons.wikimedia.org/wiki/File:UN_Sculpture_Non_Violence.jpg
