Nadir image format ?
by image360 » Thu Nov 26, 2009 6:29 pm
Trying to use a PNG format image for the nadir patch in panorama properties. It's one of the formats noted in the open dialog box, but when selected the first time I get a message saying it can not create an image file using it. Have tried PNG output from both PS4 and Fireworks so I don't think it's an issue with the particular PNG format.
What are the options here and if it's only JPG I guess that would mean the nadir has to be a rectangle since there's no blending options associated with the Nadir patch.
Regards,
Robert
by gkaefer » Thu Nov 26, 2009 7:28 pm
pngs are working for me in APT v1.1 beta 5 and in APT v1.0.6 without problem.
I used ArcSoft Photostudio 6.0
and Gimp 2.0
to produce png with default values each time...
Liebe Gruesse,
by image360 » Fri Nov 27, 2009 4:40 am
Hi Georg,
What format are your input pano files in? I'm using JPGs.
Regards,
Robert
by gkaefer » Fri Nov 27, 2009 1:24 pm
canon eos400d raws converted to 16bit tiffs.
APG stitching the tiffs
rendering the pano & saving the pano as jpg
adding this jpg inside APT to the project.
than taking the png file for the nadir patch.
Liebe Gruesse,
by image360 » Fri Nov 27, 2009 3:26 pm
Thanks Georg,
More test, it DOES seem that the PNG format produced out PS and Fireworks is NOT compatible with APT. I tried another conversion program and it was able to load into APT. The conversion program did not have any options and appears to not support transparency. This is what I was after with PNG and setting in PS and fireworks.
So, perhaps APT does not support PNG files with transparency? Georg, are you using transparency?
And, I was happy to find the project files from APT are just text files, very easy to read, understand and EDIT! This fact just saved all the work I had done on this project as it was failing to load - having trouble dealing with the PNG logo - and stopping there. I was able to open the abt file in notepad, remove the logo lines, save the file and then it opened fine.
Regards,
Robert
by gkaefer » Fri Nov 27, 2009 5:24 pm
I use gimp and tiffs for tranparancy....
lg
by mediavets » Tue Apr 27, 2010 9:23 am
Destiny wrote:Hi everyone... Regarding the Nadir Patch... It should take a PNG since that would be the most appropriate web bitmap graphic. A 24-bit PNG supports the alpha channel.. ... Nadir Patch needs to be fixed.. Any APT techo's out there???:)
It works for me - using a PNG angular map produced with Pano2VR (example attached, so you can try it) - Windows XP Pro 32-bit with SP3. and APT V1.1 beta 7:
http://www.autopano.net/forum/t7116-apt-v1.1-beta
Another user posted a report that it won't work with PNG files produced with Photoshop and Fireworks, but no-one else has reported that:
http://www.autopano.net/forum/p55460-2009-11-27-14-26-14#p55460
by mediavets » Tue Apr 27, 2010 1:36 pm
Destiny wrote:This is interesting from mediavets above. The the screen capture just dawned on me that I am using APT 1.0.6 and mediavets is using 1.1.0 beta.... Where do I download that from for my Mac...???
Destiny :)
Here:
