Autopano Tour XML export BUG
ememiks
by ememiks » Mon Nov 23, 2009 12:10 pm
I use autopano tour beta5 mac leopard version. There is a bug in xml export. The line is below;
<plugin name="closefs" align="bottom" blendmode="screen" keep="true" onclick="set(fullscreen,false);" onout="set(blendmode,screen);" onover="set(blendmode,add);" url="appledata/graphics/menu/menu8.png" visible="flase" x="120" y="10"/>
visible="flase" line must be visible="false" but i didn't understand how it effects the workflow.
Adrien F
by Adrien F » Mon Nov 23, 2009 2:59 pm
thank you for pointing this bug, it will be corrected in next version.
The "visible" property rules the way the plugin is displayed or not. The fact is that putting "flase" or "anything" instead of "false" doesn't affect the plugin, it won't be diplayed. Should be something with the way krpano interpret mispelled values.
