embedded data question
by klausesser » Fri Nov 13, 2009 6:46 pm
When i want to give ONE embedded data swf to my client - how can i edit the autorotation´s speed?
two clients already complained that they feel very uncomfortable by the fast speed of autorotation.
here´s an example using external data - but i can´t take away the ugly button. And i DON´T WANT to ue exertnal data - i want to deliver ONE swf-file to the client. The rotationspeed here is ok - i set it to 4 instead of the default set 10.
http://www.360impressions.de
by mediavets » Fri Nov 13, 2009 11:02 pm
klausesser wrote:but i can´t take away the ugly button.
'ugly button'????
by klausesser » Sat Nov 14, 2009 12:50 am
'ugly button'????
Yes - usually there´s a button to start/stop the autorotation.
The last test i used the new APT beta and it´s gone.
But i can´t edit the rotation speed when all data are embedded in ONE swf file instead of seperate files/folders.
I would like to deliver only ONE swf to the client.
best
by mediavets » Sat Nov 14, 2009 1:26 am
klausesser wrote:
'ugly button'????
best
Klaus,
I agree that it would be good for APT to offer more control over autorotation - here's what Pano2VR offers:
by klausesser » Sat Nov 14, 2009 3:15 am
mediavets wrote:Klaus,
Hi Andrew!
I found a solution - but only using seperated files. I´d like to embed all fils in one swf.
look here: http://www.360impressions.de http://www.360impressions.de/gelblich.swf
best to you, Klaus
digipano
by digipano » Sat Nov 14, 2009 3:41 am
One solution I can think of is not to embed within APT instead have xml files generated where you edit the auto rotation speed manually & then use "Kprotect" (separate product) to embed all, that way you will have control of many things.
APT is moving towards being a full GUI for karpano but its far way behind in its GUI+features yet, the APT developer team will need a tighter & faster integration of krpano feature in its GUI.
by mediavets » Sat Nov 14, 2009 11:42 am
Kprotect may indeed be an answer - more info here:
http://www.krpano.com/forum/wbb/index.php?page=Thread&threadID=331
by klausesser » Sat Nov 14, 2009 3:54 pm
Hi digipano, hi Andrew!
I´ll try it this way - sound good!
Thanks, Klaus
by klausesser » Sat Nov 14, 2009 5:33 pm
digipano wrote:One solution I can think of is not to embed within APT instead have xml files generated where you edit the auto rotation speed manually & then use "Kprotect" (separate product) to embed all, that way you will have control of many things.
hi digi!
I did what you suggested - but the sound is gone . . .
It´s not clear how to use the "protect" - they ask for the "start file" . . which one is it? There are two xml files, one of it is called xxx0.xml the other has xxx.xml
which one is the "start" file i have to put into "protect"?
a test-run without protect
Adrien F
by Adrien F » Mon Nov 16, 2009 10:57 am
As regards to property parameters you want to modify and embedd in one swf file, like <autorotate> (or <display> or <control> by the way), you can use menu templates.
Menu templates are pieces of xml code which will be included in all your visits, originally designed to design your own menu, but you can modify them to fit your needs while we are working on an all GUI tour maker.
The only thing you have to do is to create your own menu template and include the xml properties in it. Here is an example of the rotation.xml file where we have set the autorotation speed to 10° pers sec (see doc on krpano site : http://www.krpano.com/docu/xml/#autorotate) :
<menu>
    <plugin name="autorotation" url="graphics/btn_autorotation.png" blendmode="screen" keep="true" align="bottom" x="0" y="$(MARGIN)" onclick="switch(autorotate.enabled);" onover="set(blendmode,add);" onout="set(blendmode,screen);"/>
    <autorotate enabled="true"
            waittime="1.0"
            accel="5"
            speed="10"
            horizon="20"
            tofov="150"
</menu>
Using this menu template, you will be able to generate only one swf file (with 'embedd all' checked), where you control the autorotate speed.
by klausesser » Mon Nov 16, 2009 4:19 pm
Hi Adrien!
Thanks for your advice! But: how and where can i add this part to the xml when i render an embedded swf-file which contains ALL in ONE?
I´m absolutely new to xml editing - but i got a good advice rom Klaus (KRPano) already how to edit the rotation speed by adding the sequence you showed.
Another suggestion was to render seperate files in APT, edit the speed (or other items) and after that using KR-Protect to make a single swf from it.
Works well - but it´s not possible to keep integrated sound that way.
Adrien F
by Adrien F » Tue Nov 17, 2009 10:34 am
Adrien F wrote:Menu templates are pieces of xml code which will be included in all your visits
This means, once you modified those files, you won't need to do all your steps : exporting XML, edit them, embedd files in swf with kprotect, because it will be done in the software.
Step 1:
Menu templates are located in the install directory of Autopano Tour:
For Windows : C:/Programmes Files/Kolor/Autopano Tour/Templates/menu/
Mac (Ctrl click on app, display application package) : MacOs/Templates/menu/
There you'll find those files:
fullscreen-rotation.xml
fullscreen.xml
graphics/
navigation-fullscreen-rotation.xml
navigation-fullscreen.xml
navigation-rotation.xml
navigation.xml
rotation.xml
Which you can edit as I previously explained.
Step 2 :
then in APT application : Project properties > Interface > Template : use your own template and export your project. (And check 'Embedd all' if needed)
You will have your visit with a custom autorotate speed.
The advantage of this method is that you only have to do Step 1 once, and then you can reuse the same template every time you need it with Step 2 without further xml hacking.
Warning :
Concerning sound embedding : it is just not possible to embedd mp3 in one swf file. This is just a flash limitation and we can't handle it.
However there is a workaround if you REALLY need to have embedded sounds :
-Export them in swf with a dedicated soft.
-Design a very tiny, or invisible hotspot.
-Include your invisible hotspot in your visit.
-Link your sound swf file to this invisible HS.
The sound will be played immediately after the hotspot is loaded, loop endlessly (if the swf file is an endless loop), and you won't be able to stop it, nor to restart it.
There is no guarantee, this hack will work in future versions of krpano or APT.
--Edit:
Those two last posts of mine, refering to menu templates, are only valid for latests beta versions of APT, else you'll have to manually edit your xml files and re-embedd them afterward.
arniezilla
by arniezilla » Sat Jan 23, 2010 11:55 am
Step 1:
fullscreen.xml
graphics/
navigation.xml
rotation.xml
[/i]
Hello, i use Autopano Giga and there is no directory Templates/menu/ an the files
fullscreen.xml
graphics/
navigation.xml
rotation.xml
Where are these files in this Version? I need to edit the Rotationspeed.
by mediavets » Sat Jan 23, 2010 12:51 pm
arniezilla wrote:Where are these files in this Version? I need to edit the Rotationspeed.
Make sure you are using the latest version of APT - V 1.1 beta 6 - available from here:
http://www.autopano.net/forum/p51122-2009-09-07-11-54-52#p51122
Then under the Edit menu you'll find the option Open Templates Directory.
by klausesser » Sat Jan 23, 2010 1:17 pm
You have to edit the xml files to set the autorotation-speed and other things.
APT doen´t let you fine-tune your tour.
I suggest to buy the KRPano unlimited version - with the KRPano-Tools it contains a bunch of additional features, but definitely
demands some xml skills.
digipano
by digipano » Sat Jan 23, 2010 3:16 pm
klausesser wrote:I did what you suggested - but the sound is gone . . .
Thats flash imposed restriction so I convert sound MP3 to swf using MP3toswf converter then you can embed sound (swf) without any problems.
by gkaefer » Sun Jan 24, 2010 12:00 am
Step 1:
fullscreen.xml
graphics/
navigation.xml
rotation.xml
[/i]
fullscreen.xml
graphics/
navigation.xml
rotation.xml
... talking about APT - Autopano Tour - Version 1.1.0 beta 6
see: http://www.autopano.net/wiki-en/Lastest_Beta
lg
arniezilla
by arniezilla » Mon Jan 25, 2010 7:25 am
Thank you at all, i have the wrong version..... beta version correct my problem.....
