Google maps
hankkarl
Google maps
by hankkarl » Mon Sep 21, 2009 10:39 pm
Any plans on integrating google maps with KRPano? I know there's a demo on the KRPano site, but how about an integration in APT?
rodlaird
by rodlaird » Tue Sep 22, 2009 1:10 am
Hmmm - Renan - this could be done just by allowing us to specify an xml file for inclusion as part of the project settings. At the moment I have to manually edit the XML file set to include my GoogeMap radar template (which works beautifully OP - you just need to pay Klaus at krpano for the excellent googlemap.swf; it's not expensive...). It seems this general ability would be useful.
Rod in Oz
_____________________________________
NodalNinja5 Nikon D4 14-24-70-200mm f/2.8 85mm f/1.4 i7 6 core watercooled @ 4.2GHz 32GB 2100MHz DDR3 GTX570 1GB W7 x64
hankkarl
by hankkarl » Tue Sep 22, 2009 8:54 pm
The price is fine, but I'd want a good set of instructions for what XML files, etc to use.
renan
by renan » Wed Sep 23, 2009 9:14 am
It's not planed yet but I write this in the wish list...
hankkarl
by hankkarl » Wed Sep 23, 2009 1:51 pm
OK, thanks.
I'd like to see a button in APT on each pano to give access to Google Maps, then let me move around in google maps till I find the right place, then have APT automatically use that place.
Even better--use a GPS tag and automatically place the pano in google maps.
There'd also need to be some way to select how big of a map (i.e. what scale should the map be) for the tour.
HansKeesom
by HansKeesom » Fri Jul 23, 2010 1:08 pm
hankkarl wrote:OK, thanks.
This really sounds like a great idea and so logical as workflow.
Workflow I like to see
- load your pano's into autopano tour
- select all pano's which have correct GPS information inside
- push one button to have autopano-tour :
- determine the outer corners of the area the pano's have been taken
- download from google maps a map that is exactly the area determined
- place the pano's selected on the map that was downloaded
This would really be soooo easy for virtual tours that cover large (outdoor) areas like http://hanskeesom.xs4all.nl/panoramas/bijlmerpark/
Regards, Hans Keesom
