APT v1.1 beta
renan
APT v1.1 beta
by renan » Mon Sep 07, 2009 11:54 am
To answer to some last posts you can find here the list features that will be included in APT 1.1.
Donwload link beta 7 :
Windows 32 bits : http://ftp.autopano.net/releases/AutopanoTour_win32_110B7_2010-02-01.exe
Windows 64 bits : http://ftp.autopano.net/releases/AutopanoTour_x64_110B7_2010-02-01.exe
Mac Leopard : http://ftp.autopano.net/releases/AutopanoTour_Mac_Leopard_110B7_2010-02-01.dmg
Donwload link beta 6 :
Windows 32 bits : http://ftp.autopano.net/releases/AutopanoTour_win32_110B6_2009-12-11.exe
Windows 64 bits : http://ftp.autopano.net/releases/AutopanoTour_x64_110B6_2009-12-11.exe
Mac Leopard : http://ftp.autopano.net/releases/AutopanoTour_Mac_Leopard_110B6_2009-12-11.dmg
Donwload link beta 5 :
Windows 32 bits : http://ftp.autopano.net/releases/AutopanoTour_win32_110B5_2009-11-06.exe
Windows 64 bits : http://ftp.autopano.net/releases/AutopanoTour_x64_110B5_2009-11-06.exe
Mac Leopard : http://ftp.autopano.net/releases/AutopanoTour_Mac_Leopard_110B5_2009-11-06.dmg
Donwload link beta 4 :
Windows 32 bits : http://ftp.autopano.net/releases/AutopanoTour_win32_110B4_2009-10-20.exe
Windows 64 bits : http://ftp.autopano.net/releases/AutopanoTour_x64_110B4_2009-10-20.exe
Mac Tiger : http://ftp.autopano.net/releases/AutopanoTour_Mac_Tiger_110B4_2009-10-20.dmg
Mac Leopard : http://ftp.autopano.net/releases/AutopanoTour_Mac_Leopard_110B4_2009-10-20.dmg
Donwload link beta 3 :
Windows 32 bits : http://ftp.autopano.net/releases/AutopanoTour_win32_110B3_2009-09-16.exe
Windows 64 bits : http://ftp.autopano.net/releases/AutopanoTour_x64_110B3_2009-09-16.exe
Mac Tiger : http://ftp.autopano.net/releases/AutopanoTour_Mac_Tiger_110B3_2009-09-16.dmg
Mac Leopard : http://ftp.autopano.net/releases/AutopanoTour_Mac_Leopard_110B3_2009-09-16.dmg
Linux 32 bits Deb : http://ftp.autopano.net/releases/AutopanoTour_Linux32_110B3_2009-09-16.deb
Linux 32 bits TGZ : http://ftp.autopano.net/releases/AutopanoTour_Linux32_110B3_2009-09-16.tar.gz
Linux 64 bits Deb : http://ftp.autopano.net/releases/AutopanoTour_Linux64_110B3_2009-09-16.deb
Linux 64 bits TGZ : http://ftp.autopano.net/releases/AutopanoTour_Linux64_110B3_2009-09-16.tar.gz
== beta 7 ==
new features:
* Selection in spot edition area permits to edit spot properties
* Replacement of "mode move" by "mode select"
* Multiple selection in spot edition area (<Ctrl>+click or <Ctrl>+A) : only in "mode select"
* <nowiki><Del></nowiki> key delete spot selection in edition area
* Map hotspot is flashing when concerned pano is beeing viewed
* Logo size in pix and %
fixed:
* multiple lensflares in one pano is now possible
* "max preview width" is changed to "max preview size" to correct a bug for vertical panoramas
* names shown in thumbnail are the name of the pano (not the one of the related xml file)
* Thumbnail : horizontal view allows more than one line
* Thumbnail : no more height asked : all is relative to width
* Export : numbers are not allowed as first character of an output file (for beeing compatible with krpano)
* Pictures with one dimension inferior to the cutting size were not cut, leading to "too big picture" for flash in some configurations.
known bug:
* Thumbnail : if you stretch the window along width, size of thumbnail pictures will grow but not the height of the thumbnail plugin. This may cause overlapping of thumbnail pictures in some cases.
== beta 6 ==
new features:
* possibility to export a panel of thumbnails
* possibility to draw polygon and rectangular hotspot over 180° (in full 360° nadir and zenith become selectable)
fixed:
* large partial panoramas were not well exported for non-krpano user
* video and sound files are never embedded (flash can't play embedded streams)
* full 360 were not displayed if original size was smaller than the preview
improvements:
* map resizing by keeping aspect ratio
* more possibilities for drawing rectangular hotspots
== beta 5 ==
bugs fixed :
* exported black window
* freeze while drawing or exporting rectangular hotspot
* rename of all media exported (picture, sound...) to prevent unauthorized characters
* objects linked by hotspot of map was displayed on first panorama only
* hotspot sounds was not saved in project file or in the history
== beta 4 ==
bugs fixed :
* large panorama picture can use the 'embed all' option
* progress, control, display and contextmenu xml nodes can de added in menu templates
* default punctual object was displayed in all type of hotspot
* autorotation was enable only on the first panorama
new features :
* add a global sound
* export limited domain virtual tour : external xml embedding is now possible within a web domain
improvements:
* more option for polygon color (separate border and fill)
* map size can be expressed in pourcent
* sound and video interaction
== beta 3 ==
* krpano registration:
To improve the security, krapno tools license is also needed.
Branding free licence can be included in the project.
* language menu:
Possibility to switch between available languages.
* Missing files:
When you open a project which has been displaced you can manually correct brocken links.
* History tools:
Same as most of history tools.
* Map:
You can add a map to the project. When the map is added and selected, you can add punctual hotspots on it and link these hotspots as all other hotspots.
* Templates:
Some properties of APT has been moved in template files. All possiblities of APT 1.0 can be set by using default templates. But you can add your own templates to use more krpano possibilities.
** Font properties + font templates:
You can change the font properties and add special effects via xml template files.<br/>Template files have to be put in the "Templates\textstyle" directory. One template is a krpano textstyle. All attributes which cannot be edited from APT interface will use the template file to be set.
** Menu templates:
You can add krpano menu template files in "Templates\menu" directory. This is standard krpano code except that $(MARGIN) tag will be replaced by the margin property editable in APT UI.
** Progress templates:
You can add krpano progress template files in "Templates\progress".
** Transition templates:
You can add transition template files in "Templates\transition". These templates are used to associate an animated transition to hotspot which links a panorama.
You can use all krpano actions and some tags or xml attribute will use APT edited properties:
*** $(PANO) will be replaced by the linked panorama xml file
*** hcenter and vcenter are the coordinates of the hotspot center
*** hview, vview, fovview are the hotspot view parameters edited in APT
*** panoview.h, panoview.v, panoview.fov are the default panorama view parameters edited in APT
** html templates:
If the template use external files (as java script files), copy these files in a directory wich have the same name that the HTML template file. They will be automatically copied when the template is used.
* Rectangular hotspots:
A new tool for editing rectangular hotspot has been added. The last point of the hotspot is guided do be sure that drawn hotspot can be represented by a 3D rectangle in the krpano player.
This hotspot will use the last distorted hotspots. So you can attach a graphical objet which be perfectly incrusted in the panorama.
* Flying hotspots:
If a rectangular hotspot has the same graphical object in display field and in link field this object will be animated from hotspot position to "flying" position.
* embedded object size can be defined proportionally to scene size.
(Does not work with flying spot)
* Videoplayer plugin:
If graphical objects are *.flv files the krpano videoplayer plugin is used.
* sound :
** play a sound while a panorama is loaded
** play a sound on hotspot click
* planar export :
if you want to export a zoomify like panorama, put 0 in horizontal or vertical parameter of "Data field of view".
* Cutting size:
You can set size used to cut large panorama in multiresolution format. If 0 is set the multiresolution is disabled (useful for local applications).
* Export without panorama picture:
Usefull to re-export a project when panoramas haven't changed and when data are not embedded into the flash file.
* default parameters saving :
On each properties widget you can save default parameters.
All properties are not saved :
** project : map properties are not saved
** panorama : cutting size, preview size, jpeg quality, fov limits are saved
** hotspot : color, visible on over, displayed object, transition template are saved
Default panorama or hotspot parameters can be saved only if one object is selected.
* open templates directory :
launch a browser to open templates directories.
* open last exported project :
launch the swf file or the html file exported.
digipano
by digipano » Mon Sep 07, 2009 12:28 pm
* Templates:
Does this mean that we can now add the xml code once in the template (Eg: various projection "context menu") & then output to that template?
** Menu templates:
Need to see what actually does it add to the actual panorama, as of now we have only one drop down menu, can we now have thumbnails added vertically or horizontally by making our own template? I guess we still need to edit the XML to do so.
can we now use our own flash loaders?
What we need or look forward to is APT becoming the main GUI for krpano, is that the road map APT will follow in near future?
by AlexandreJ » Mon Sep 07, 2009 1:41 pm
digipano wrote:What we need or look forward to is APT becoming the main GUI for krpano, is that the road map APT will follow in near future?
Yes, that's the aim. Klaus agreed to consider Autopano Tour as the official Tour GUI for krpano. And yes, it will be provided in a standalone package too.
aimache
by aimache » Mon Sep 07, 2009 4:11 pm
I see many interesting things in this list, thanks for sharing it: APT's future looks brilliant :)
renan
by renan » Mon Sep 07, 2009 4:12 pm
digipano wrote:Does this mean that we can now add the xml code once in the template (Eg: various projection "context menu") & then output to that template?
Yes, xml code and graphical objects of the menu template will be included in the code generated by APT.
digipano wrote:Need to see what actually does it add to the actual panorama, as of now we have only one drop down menu, can we now have thumbnails added vertically or horizontally by making our own template? I guess we still need to edit the XML to do so.
Thumbnails pluggin need to have access to panorama picture (to create the thumbnails) and this kind of feature is not possible with menu template.
digipano wrote:can we now use our own flash loaders?
You can define the parameters of the "progress" node of krpano.
by gkaefer » Mon Sep 07, 2009 4:25 pm
on krpano forum the question was asked, if this autopano tour update will also also available for mac users...
http://krpano.com/forum/wbb/index.php?page=Thread&threadID=543&pageNo=3
Liebe Gruesse,
digipano
by digipano » Mon Sep 07, 2009 4:56 pm
Alex reply indicate that APT will be available as standalone software so I guess there will be a mac version too, may be sooner or later.
If not via menu template is there any other way we can add thumbnails to the tour with having options of placement of thumbnails? MY guess is that's quite a basic feature most tours would need in some form or other.
lizard.king
by lizard.king » Thu Sep 17, 2009 12:43 pm
Will APT 1.1 also allow for higher output resolutions when used with krpano?
The current resolution limits are really a showstopper for me. I want to work with resolutions >1 Gigapixel.
Canon 50D, Canon EF-S 10-22mm, Sigma 17-70mm, Canon 100mm Macro, Canon 70-300mm
Merlin Pano Head
Gigapan Beta
Autopano Giga, APT, KRPano unlimited
yodabel
Likes: 9 posts
Liked in: 4 posts
by yodabel » Fri Sep 18, 2009 10:50 am
Good job ! ;-D
by gkaefer » Fri Sep 18, 2009 5:40 pm
if you've an unlimited krpano license bought with your AP notice this using APT v1.1.0 beta3:
(win7rc64bits & autopano giga 2.0.4 and autopano tour 1.04 installed and than autopano tour 1.1.0 beta 3 finally upgraded)
by default only the krpano license will be found by APT.
open menu Register->RegisterKRPano...
KRPano License will show your license
KRPano Tools License will now be shown.... so klick on folder symbol on right side and go to following (if you used default locations):
C:\Program Files\Kolor\licence_xxxxxx\
here are located. Choose the first one
krpanotools.license
krpano.license
finally press OK
lg
scraffe
by scraffe » Sat Sep 19, 2009 1:08 am
Une petite question sur APT 1.1 :
Est ce que le fichier .swf qui sort d'APT et le même que celui de krpano.swf.
Car je cherche a utiliser le passage de paramètres d'url dans le .HTML (?pano=xxx.xml) mais si je laisse le fichier swf qui sort d'APT cela ne fonctionne pas ? meme apres avoir modifier les fichiers comme il faut je pense ?!
LE FICHIER HTML
<html>
<head>
    <title>ESDI TEST visites multi-entree example</title>
</head>
<style>
body{ font-family:Arial, Helvetica, sans-serif; font-size:10px; color:#FFFFFF; background-color:#000000; margin:0; padding:0; }
* html, * html body{ overflow: hidden; }
a{ color:#555555; text-decoration:underline; }
a:hover{ color:#AAAAAA; text-decoration:underline; }
</style>
<body>
<div id="test-1-1">
    <noscript><table width="100%" height="100%"><tr valign="middle"><td><center>ERROR:<br><br>Javascript not activated<br><br></center></td></tr></table></noscript>
</div>
<script type="text/javascript" src="./swfobject/swfobject.js"></script>
<script type="text/javascript" src="./swfobject/swfkrpanomousewheel.js"></script>
<script type="text/javascript">
// <![CDATA[
    if (typeof(deconcept) !== 'undefined' && deconcept.SWFObjectUtil.getPlayerVersion().major >= 6)
        var so = new SWFObject("test-1-1.swf", "krpanoSWFObject", "100%", "100%", "9.0.28","#000000");
        so.addParam("allowFullScreen","true");
        so.addParam("allowScriptAccess","sameDomain");
        //so.addVariable("pano", getQueryParamValue("pano"));
        // pass all external parameters
        var q = document.location.search || document.location.hash;
        if(q)
            var params = q.substring(1).split("&");
            for(var i=0; i<params.length; i++)
                var param = params[i];
                var istgl = param.indexOf("=");
                var pname = param.substring(0,istgl);
                var pval  = param.substring(istgl+1);
                if (pname == "krpanologo")
                    // shortcut to hide the logo
                    pname = "plugin[krpanologo].visible";
                so.addVariable(pname, pval);
        so.useExpressInstall('./swfobject/expressinstall.swf');
        so.setAttribute('xiRedirectUrl', window.location);
        if ( so.write("test-1-1") ) { var mousewheelfixes = new SWFkrpanoMouseWheel(so); }
    else
        document.getElementById("test-1-1").innerHTML = '<table width="100%" height="100%"><tr valign="middle"><td><center>ERROR:<br><br>Adobe Flash Player 9 needed<br><br><br><a href="http://www.adobe.com/go/getflashplayer/"  target="_blank"><IMG SRC="http://www.macromedia.com/images/shared/download_buttons/get_flash_player.gif" BORDER="1"></a><br>...cliquez ici pour telecharger...<br><br><br><br></center></td></tr></table>';
</script>
</body>
</html>
LE FICHIER DE PARAMETRES :
<krpano version="1.0.8" logkey="false">
    <textstyle name="DEFAULT" alpha="1" bold="false" font="Arial" fontsize="16" italic="false" textcolor="0xff000000"/>
    <plugin name="in" align="bottom" keep="true" ondown="set(movevectorz,-1);" onout="set(blendmode,normal);" onover="set(blendmode,add);" onup="set(movevectorz,0);" url="test-1-1data/graphics/menu0.png" x="-160" y="10"/>
    <plugin name="out" align="bottom" keep="true" ondown="set(movevectorz,+1);" onout="set(blendmode,normal);" onover="set(blendmode,add);" onup="set(movevectorz,0);" url="test-1-1data/graphics/menu1.png" x="-120" y="10"/>
    <plugin name="left" align="bottom" keep="true" ondown="set(movevectorx,-1);" onout="set(blendmode,normal);" onover="set(blendmode,add);" onup="set(movevectorx,0);" url="test-1-1data/graphics/menu2.png" x="-80" y="10"/>
    <plugin name="right" align="bottom" keep="true" ondown="set(movevectorx,+1);" onout="set(blendmode,normal);" onover="set(blendmode,add);" onup="set(movevectorx,0);" url="test-1-1data/graphics/menu3.png" x="-40" y="10"/>
    <plugin name="up" align="bottom" keep="true" ondown="set(movevectory,-1);" onout="set(blendmode,normal);" onover="set(blendmode,add);" onup="set(movevectory,0);" url="test-1-1data/graphics/menu4.png" x="0" y="10"/>
    <plugin name="down" align="bottom" keep="true" ondown="set(movevectory,+1);" onout="set(blendmode,normal);" onover="set(blendmode,add);" onup="set(movevectory,0);" url="test-1-1data/graphics/menu5.png" x="40" y="10"/>
    <plugin name="home" align="bottom" blendmode="normal" keep="true" onclick="lookto(get(panoview.h),get(panoview.v),get(panoview.fov),smooth(100,20,50));" onout="set(blendmode,normal);" onover="set(blendmode,add);" url="test-1-1data/graphics/menu6.png" x="80" y="10"/>
    <plugin name="openfs" align="bottom" blendmode="screen" keep="true" onclick="set(fullscreen,true);" onout="set(blendmode,screen);" onover="set(blendmode,add);" url="test-1-1data/graphics/menu7.png" x="120" y="10"/>
    <plugin name="closefs" align="bottom" blendmode="screen" keep="true" onclick="set(fullscreen,false);" onout="set(blendmode,screen);" onover="set(blendmode,add);" url="test-1-1data/graphics/menu8.png" visible="flase" x="120" y="10"/>
    <events onenterfullscreen="set(plugin[openfs].visible,false); set(plugin[closefs].visible,true);" onexitfullscreen="set(plugin[openfs].visible,true); set(plugin[closefs].visible,false);"/>
    <plugin name="autorotation" align="bottom" blendmode="screen" keep="true" onclick="switch(autorotate.enabled);" onout="set(blendmode,screen);" onover="set(blendmode,add);" url="test-1-1data/graphics/menu9.png" x="160" y="10"/>
    <plugin name="map" url="test-1-1data/map/map.png" keep="true" align="righttop" x="10" y="10" width="854" height="400" handcursor="false" onclick="action(closemap);"/>
    <plugin keep="true" name="mapspot0" hview="0" vview="0" fovview="90" hcenter="" vcenter="" onclick="lookto(get(hcenter),get(vcenter),get(view.fovmin),smooth(400,20,100));loadpano(test-1-11.xml,null,null,BLEND(1));lookat(get(hview),get(vview),get(fovview));wait(blend);lookto(get(panoview.h),get(panoview.v),get(panoview.fov),smooth(100,20,50));" url="test-1-1data/spots/mappoint.png" align="righttop" edge="center" x="632.633" y="173.402"/>
    <action name="showmapspot">set(plugin[mapspot0].alpha,0);set(plugin[mapspot0].visible,true);tween(plugin[mapspot0].alpha,1);</action>
    <action name="hidemapspot">set(plugin[mapspot0].visible,false);</action>
    <action name="closemap">action(hidemapspot);set(plugin[map].onclick,action(openmap););tween(plugin[map].width,40);tween(plugin[map].height,40);</action>
    <action name="openmap">set(plugin[map].onclick,action(closemap););tween(plugin[map].width,854);tween(plugin[map].height,400,0.5,easeoutquad,action(showmapspot););</action>
</krpano>
ET LE FICHIER D'UN PANO AU HAZARD : (celui ci appelant le fichier global à  chaque image)
<krpano version="1.0.8">
    <include url="test-1-1.xml"/>
    <panoview h="0" v="0" fov="90"/>
    <view fisheye="0" limitview="lookat" vlookatmin="-90" vlookatmax="90" fovmin="0.01" fovmax="179" fov="90" hlookat="0" vlookat="0"/>
    <preview url="test-1-1data/test-1-10/preview.jpg"/>
    <image type="CUBE" multires="true" tilesize="637" baseindex="0">
        <level tiledimagewidth="2547" tiledimageheight="2547">
            <left url="test-1-1data/test-1-10/3/2/%v_%u.jpg"/>
            <front url="test-1-1data/test-1-10/0/2/%v_%u.jpg"/>
            <right url="test-1-1data/test-1-10/1/2/%v_%u.jpg"/>
            <back url="test-1-1data/test-1-10/2/2/%v_%u.jpg"/>
            <up url="test-1-1data/test-1-10/4/2/%v_%u.jpg"/>
            <down url="test-1-1data/test-1-10/5/2/%v_%u.jpg"/>
        </level>
        <level tiledimagewidth="1274" tiledimageheight="1274">
            <left url="test-1-1data/test-1-10/3/1/%v_%u.jpg"/>
            <front url="test-1-1data/test-1-10/0/1/%v_%u.jpg"/>
            <right url="test-1-1data/test-1-10/1/1/%v_%u.jpg"/>
            <back url="test-1-1data/test-1-10/2/1/%v_%u.jpg"/>
            <up url="test-1-1data/test-1-10/4/1/%v_%u.jpg"/>
            <down url="test-1-1data/test-1-10/5/1/%v_%u.jpg"/>
        </level>
        <level tiledimagewidth="637" tiledimageheight="637">
            <left url="test-1-1data/test-1-10/3/0/%v_%u.jpg"/>
            <front url="test-1-1data/test-1-10/0/0/%v_%u.jpg"/>
            <right url="test-1-1data/test-1-10/1/0/%v_%u.jpg"/>
            <back url="test-1-1data/test-1-10/2/0/%v_%u.jpg"/>
            <up url="test-1-1data/test-1-10/4/0/%v_%u.jpg"/>
            <down url="test-1-1data/test-1-10/5/0/%v_%u.jpg"/>
        </level>
    </image>
    <hotspot name="spot0" hview="0" vview="0" fovview="90" hcenter="6.76692" vcenter="2.26131" onclick="loadpano(test-1-11.xml,null,null,BLEND(1));lookat(get(hview),get(vview),get(fovview));wait(blend);lookto(get(panoview.h),get(panoview.v),get(panoview.fov),smooth(100,20,50));" url="test-1-1data/spots/hotspot_ani.swf" ath="366.767" atv="2.26131"/>
</krpano>
Et bien comme c'est la, ça ne marche pas, mais si je remplace "test-1-1" dans le fichier html par krpano cela fonctionne parfaitement et je peux atteindre le pano que je veux au départ de la visite...
Si vous avez une idée pour éviter de modifier le html qui sort d'APT et de copier le krpano.swf a chaque fois de plus j'ai l'impression que cela m'oblige a gérer la licence à  coté ?!
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Sat Sep 19, 2009 9:22 am
Est-il prévu le support du multiprocessing dans APT ? car pour le moment de ce que j'en vois avec la version Béta sur Mac (Snow Leopard), il fait mouliner à  fond l'ordi mais sur un seul processeur :(
En tout cas merci pour cette super bêta avec pleins de nouvelles fonctions sympas pour mieux gérer KRPano et sa puissance :P
Merci
Vince
Blog: http://www.skivr.com
digipano
by digipano » Sat Sep 19, 2009 2:14 pm
Renan
What are Krpano special features, are they not yet implemented?
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Sat Sep 19, 2009 3:58 pm
Par contre deux bugs toujours un peu déroutant:
-> lorsqu'on passe d'une image à  l'autre dans la fenêtre avec tous les panos de la visite, sur Mac, j'ai la pizza qui tourne pendant quelques secondes ce qui fait toujours peur d'un crash :( Pas possible d'avoir plutôt un sablier ou qq chose dans le genre ?
-> lors de la génération de la visite virtuelle, au dernier stade lorsqu'il copie les fichiers cela reste un bon moment figé (la barre de progression bleue ne tourne même plus) et là  aussi on peut se demander si ça a pas crashé ! En fait ça reste à  ce stade une éternité alors qu'à  priori l'export est bien fini car la visite virtuelle est fonctionnelle mais cette fenêtre interminable reste là  bien trop longtemps :(
Merci en tout cas pour le super avancement de ce petit programme qui commence à  devenir vraiment très sympa :)
Vincèn
renan
by renan » Mon Sep 21, 2009 2:58 pm
scraffe wrote:Une petite question sur APT 1.1 :
krpano.swf is the 1.0.8 beta9 (soon available on krpano web site)
renan
by renan » Mon Sep 21, 2009 3:00 pm
digipano wrote:What are Krpano special features, are they not yet implemented?
http://www.autopano.net/forum/t7225-apt-1.1-beta3-try-krpano-special-features
renan
by renan » Mon Sep 21, 2009 3:13 pm
vincen wrote:-> lorsqu'on passe d'une image à  l'autre dans la fenêtre avec tous les panos de la visite, sur Mac, j'ai la pizza qui tourne pendant quelques secondes ce qui fait toujours peur d'un crash :( Pas possible d'avoir plutôt un sablier ou qq chose dans le genre ?
ceci peut être modifier en changeant le modèle de barre de progression.
vincen wrote:-> lors de la génération de la visite virtuelle, au dernier stade lorsqu'il copie les fichiers cela reste un bon moment figé (la barre de progression bleue ne tourne même plus) et là  aussi on peut se demander si ça a pas crashé ! En fait ça reste à  ce stade une éternité alors qu'à  priori l'export est bien fini car la visite virtuelle est fonctionnelle mais cette fenêtre interminable reste là  bien trop longtemps :(
la ganularité de la progression doit être améliorée. La visite peut fonctionner car les fichiers sont chargés au fur et à  mesure. Le hasard doit faire que les fichiers non encore copiés ne sont pas utilisés dès l'ouverture de la visite...
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Mon Sep 21, 2009 4:18 pm
Euh me suis bien exprimé ? je parle quand on est dans APT, pas dans la visite virtuelle ;)
Oui effectivement la granularité de cette barre de progression dans APT gagnerait beaucoup à  s'améliorer et vérifier si elle reste pas plus longtemps que de raison car il me semble qu'APT met quand même énormément de temps lors de l'étape copie des fichiers :(
Merci
Vincèn
scraffe
by scraffe » Sat Sep 26, 2009 5:08 pm
GENIAL :D:D
Juste une ou deux choses :
Dans APT, j'ai compris que l'on pouvais modifier les modèles HTML et MENU afin de charger des plugins perso facilement, par contre, je n'arrive pas a insérer ceci dans mon xml générale :
les includes et les <contextmenu> disparaisse à  la compilation si je les mets dans un modèle de menu !?
Mon but et de simplifier l'intégration de diverses plugins suivant la commande du client pour m'avancer au mieux, j'ai réussi a faire une interface en AS3 qui gère pas mal de chose dont l'ouverture de carte, vignette, gestion du son et de la direction, aide et autres, je contrôle bien mes plugins, par contre pour optimiser APT, je pense qu'il serait judicieux de pouvoir placer un include dans le xml générale avec ses propres XML suivant les besoins.
Un exemple, je voudrais integré le plugin as3Thumbsforkrpano, mais celui ci ayant un paramètre après son nom, APT ne peux pas me le charger depuis le modele de menu (il ne trouve pas le fichier, normal, mais cela bloque le reste) :
<plugin name="thumbnails" url="as3Thumbsforkrpano.swf?TheXML=gallery1.xml" capture="false" keep="true" align="top" scale=".0" x="0" y="10" />
Voila, si vous aviez une idée, cela m'éviterais de modifier trop les fichiers après la sorti d'APT... Je suis peut être gourmand, mais jusqu'à  ce jours j'utilisais tourweaver pro et j'avoue qu'il a l'avantage de gérer les radars et les vignettes de façon simple et entièrement automatisé.
Par contre, je reconnais a APT et à  KRPANO leur trés grande qualité et le résultat que l'on peut en tirer!
Encore bravo messieurs :D
scraffe
by scraffe » Sat Sep 26, 2009 5:24 pm
Autres petite question déja relevé mais pas vraiment solutionné !
Je fais des visite "multi entrée" diront nous avec "sommet.html?pano=sommet0.xml" par exemple, je modifie XML générale en supprimant <include url="sommet0.xml"/> du début et je place <include url="sommet.xml"/> dans chaque fichier pour qu'il me charge les paramètres. cela ne fonctionne pas si je ne change pas le swf sommet.swf qui sort d'APT et que je le remplace par le krpano.swf classique, vous m'avez dit utiliser le krpano 1.0.8 beta 9 est ce que cela vient de cela car j'utilise le 1.0.8 beta 8 ?
Merci de vos lumières.
renan
by renan » Mon Sep 28, 2009 8:47 am
scraffe wrote:les includes et les <contextmenu> disparaisse à  la compilation si je les mets dans un modèle de menu !?
C'est un bug identifié, se sera corrigé dans la prochaine mise à  jour.
Pour le plugin as3Thumbsforkrpano, c'est la syntaxe de passage des paramètres qui coince. Je regarderai ça de plus près pour voir ce qui est possible de faire.
renan
by renan » Mon Sep 28, 2009 8:58 am
scraffe wrote:Je fais des visite "multi entrée" diront nous avec "sommet.html?pano=sommet0.xml" par exemple, je modifie XML générale en supprimant <include url="sommet0.xml"/> du début et je place <include url="sommet.xml"/> dans chaque fichier pour qu'il me charge les paramètres. cela ne fonctionne pas ...
Comme nous incluons la licence dans le fichier swf, le chargement dynamique est désactivé afin d'éviter que le player soit détourné par une autre personne que vous.
Je vais voir si nous pouvons ajouter une option pour déverrouiller cela mais dans tous les cas il faudra être prudent à  l'usage...
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Fri Oct 02, 2009 6:34 am
A new beta avalaible soon Renan ? too impatient to test new features :D
scraffe
by scraffe » Fri Oct 02, 2009 9:53 am
Et t'il possible de mettre la licence dans un autre répertoire et d'y coller un .htaccess pour protège le rep ?
Sinon, je m'éclate avec APT 1.1
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Fri Oct 02, 2009 10:30 am
scraffe wrote:Et t'il possible de mettre la licence dans un autre répertoire et d'y coller un .htaccess pour protège le rep ?
Non pas possible parce que quand le flash va se charger il faut qu'il puisse accéder au fichier de license et s'il est protégé par un .htaccess ça va pas le faire :(
scraffe wrote:Sinon, je m'éclate avec APT 1.1
Toi aussi :D me demande pourquoi AutoPano Tour intègre pas encore toutes les options de KRPano :cool: Renan ? :D En tout cas ça avance dans le bon sens et c'est vraiment cool d'avoir un GUI simple et efficace pour faire les visites virtuelles ;)
Vince
