XML and other errors
RickDrew
by RickDrew » Mon Aug 17, 2009 1:47 am
I'm trying out the tour program for the 1st time (I also have a KRpano license) - If I add a dropdown list, I get an error. If I remove the dropdown, no error.
combobox selection() syntax error
I also receive random errors for text styles ( text style "stationary bikes" not found ) - stationary bikes being the text in the hotspot.
Plus, when the pano first loads, it shows the overlay with the KRpano version, license information, etc. I really don't want that to show by default.
Major bug - I was attempting to delete a hotspot. Accidentally deleter the pano. Closed - did NOT save. Reopened. The deleted pano was still gone.
Any ideas?
Rick Drew
RickDrew
by RickDrew » Mon Aug 17, 2009 3:34 am
The random text errors - I think these are caused by having a colon ":" in my text.
renan
by renan » Mon Aug 17, 2009 10:44 am
Can you send me the *.apt project file for seeing what can be wrong with droplist and tooltips ? (I don't need to have pictures)
For the overlay, it's appear only when there is some errors in the xml code...
Did you reproduce you "saving" bug ? (I don't reproduce it with the last 1.0.3 version)
RickDrew
by RickDrew » Mon Aug 17, 2009 11:05 am
I figured there was an error in the XML code, but all I did was use the built-in drop-down list feature. If works, but the error report appears.
Also, is there a way to hide the registration / debugging info when the pano loads?
Rick
