Hotspot transitions
Hotspot transitions
by mediavets » Tue Apr 28, 2009 10:44 am
When using hosptpots to move between panos I would like to have a choice of transition 'styles'.
Right now we have zoom in-out, I would particularly like to a have fade-in-out option, as I think it's less 'disturbing' than zoom in-out.
renan
by renan » Tue Apr 28, 2009 3:37 pm
If you disable the zoom in option and you don't set a destination view, transition will be a simple fade-in-out.
By default destination view is not setted, so you just have to uncheck the zoom-in option of the hotspot.
by mediavets » Tue Apr 28, 2009 3:55 pm
renan wrote:If you disable the zoom in option and you don't set a destination view, transition will be a simple fade-in-out.
OK. But I might like to choose a destination view and also have a fade-in/out transition?
renan
by renan » Tue Apr 28, 2009 4:18 pm
The panorama will be load at the start view which can be setted without activating the transition.
If what you need, is to have a start view which depends of the hotspot, it's not currently possible. But it's noted for future evolutions...
by mediavets » Tue Apr 28, 2009 4:21 pm
renan wrote:The panorama will be load at the start view which can be setted without activating the transition.
OK.
