[winxp SP3 Alpha 2 APT] How to define view at 'end' of hotspot?
by mediavets » Mon Dec 22, 2008 10:39 pm
I have watched the preview video and played a little with APT but don't understand how you define the destination FOV for a hot spot.
Is there any means of setting zoom limts or FOV limits for a pano in APT as is there is in Pano2VR?
renan
by renan » Mon Jan 05, 2009 2:10 pm
The current version doesn’t enable to set destination fov of a hotspot. You can set the start fov for each panorama by context menu of the 3D view. All hotspots which load the same panorama will start with the same fov.
Min and max fov are also set by context menu of the 3D view.
by mediavets » Mon Jan 05, 2009 2:26 pm
renan wrote:The current version doesn’t enable to set destination fov of a hotspot. You can set the start fov for each panorama by context menu of the 3D view. All hotspots which load the same panorama will start with the same fov.
OK - but are there plans to offer the ability to set different destination FOVs for individual hotspots?
I can envisage a very clumsy workaround - having multiple versions of same pano with different names - but ....
renan
by renan » Mon Jan 05, 2009 5:15 pm
We don’t know yet if this feature will be directly available in APT for version 1.0.
In all case, with a KRPano license APT will export a code skeleton which enables to use all KRPano capabilities. Defining final hotspot fov and animated transitions will possible by this way (and maybe directly in apt ;) …)
