Map
Gerrit
Map
by Gerrit » Tue May 17, 2011 11:34 am
Good day.
I recently spent with PTP I want to try the small map icon should be replaced by another symbol, this is the same as the big map, is that possible?
by mediavets » Tue May 17, 2011 11:40 am
Welcome to the forum...
I don't understand what it is you want to do.
Can you provide a more complete explanation perhaps with a mock-up screenshot?
Gerrit
by Gerrit » Tue May 17, 2011 12:00 pm
I mean the following.
I would like the map in figure 2 is replaced by another image, a symbol more than a small reproduction of the map that I see now.
by Destiny » Tue May 17, 2011 12:32 pm
Thats an interesting point you have raised.. but I am sure the answer to that is no... I have just checked out the xml code.. there is no second image that can be replaced for it... The folder has only the map image in it.. good point though.. oh kolor tech'o guy.. A nice button or something else would be much better than that thumb map... for sure...
Gerrit
by Gerrit » Tue May 17, 2011 12:40 pm
I am also busy in the XML code, I was there some change but not the desired result.
