Non-pano Images and Object/Item descriptions.
MintyFRESH
by MintyFRESH » Sun Jan 16, 2011 2:03 pm
Hi
I seem to be missing fuctions in my copy of AutoPano Tour compared to other users.
Under panorama properties I should see four tabs...
-Picture parameters
-Data feild of view
-View parameters
-Sound
They just do not exist at all and I would like to add non-pano still images to my tour. I am running version 1.0.9.
Secondly could you reccomend on the following. Say for instance I am in a room (the tour) and there is an object of significance. I would like to be able to click on this object and bring up a close up shot of it with a description. What would be the best way to acheive this? Would I need to create an object board in a programme such as Adobe Illustrator and then insert this as a non-pano still image to my tour providing hotspots between the two?
Any suggestions warmly appreciated.
MintyFRESH
by MintyFRESH » Sun Jan 16, 2011 2:19 pm
Something else I wanted to ask is with regards to the icons used to make the transition between loaded panoramas. If i do not want to use the black hypnotic circles (best way I can think to describe them) to make the transition must I create an alternative icon myself?
MintyFRESH
by MintyFRESH » Sun Jan 16, 2011 6:06 pm
Ok update. All the above problems are now sloved!
New Problem - Sound.
Under the sound tab the folder icon is greyed out. I have tried closing the programme and re-opening and also starting a new tour. Any ideas please? :-S
by mediavets » Sun Jan 16, 2011 6:19 pm
MintyFRESH wrote:Ok update. All the above problems are now sloved!
Welcome to the forum...
To enable sound (and video, and some other features) you need a krpano licence with Autopano Tour; or to have a licence for Panotour Pro.
Autopano Tour will soon be superceded by Panotour and Panotour Pro.
Panotour is roughly equivalent to Autopano Tour; and Panotour Pro is roughly equivalent to Autopano Tour + krpano.
If you have an Autopano Giga licence you can get a free licence key for Panotour.
If you have licences for both Autopano Giga and krpano you can get a free licence key for Panotour Pro.
See:
http://www.autopano.net/wiki-en/action/view/FAQ_-_Frequently_Asked_Questions#Criterias_to_get_Panotour.2FPanotour_Pro_.3F
