cant insart a still image
asafmordechai
by asafmordechai » Tue Oct 19, 2010 2:23 pm
hello.
i got the Autopano Giga 2 + Autopano Tour and got the kprotect licenc the 199euro offer
i have win 7 64 bit.
i am trying to insert a still image to the tour ( as explained in that post http://www.autopano.net/forum/t10081-non-panoramic-stills-in-ap-tour)
but didn't help.
i am using the V1.1 beta 11
by mediavets » Tue Oct 19, 2010 2:33 pm
So what's the problem? - just add the still image as you would a pano image and then change the Panorama Properties/Data field of view/Output projection to Planar
asafmordechai
by asafmordechai » Tue Oct 19, 2010 2:52 pm
look at that ...
by mediavets » Tue Oct 19, 2010 4:31 pm
So? I got the impression that you could not insert a still image in a tour.
You have done so.
Perhaps you meant 'I have inserted a still image ina tour but it does not display in the way I wish'?
What size is that still image? In pixels?
Did you set the Initial/default FOV? and Max/Min zoom?
asafmordechai
by asafmordechai » Tue Oct 19, 2010 5:03 pm
i don't understand the image is still doesn't display properly.
the image should be like in the small picture but its not.
I don't see the bottom or zoom out ...
by mediavets » Tue Oct 19, 2010 6:02 pm
You can right-click in the 3D Editor view to set the Initial/default FOV and Max/Min zoom.
Does your still image really need to have such a high resolution.
asafmordechai
by asafmordechai » Tue Oct 19, 2010 6:47 pm
OK, i will try.
Is that to large image for the program ?
it is probably something so simple, but it doesn't working for me.
by mediavets » Tue Oct 19, 2010 6:52 pm
asafmordechai wrote:OK, i will try.
How large is it?
asafmordechai
by asafmordechai » Tue Oct 19, 2010 6:56 pm
3 mb
by mediavets » Tue Oct 19, 2010 7:04 pm
asafmordechai wrote:it is probably something so simple, but it doesn't working for me.
3 mb
If you can put the image on-line I'll download it and see if I can work out what's happening.
asafmordechai
by asafmordechai » Tue Oct 19, 2010 7:15 pm
OK its working now as you said.
i didn't registered the kprotect license correctly there are 2 flies, i just copied them to the autopano folder.
by mediavets » Wed Oct 20, 2010 1:05 pm
asafmordechai wrote:OK its working now as you said.
OK.
BTW I think you mean krpano and krpanotools licences - kprotect is something else altogether.
asafmordechai
by asafmordechai » Wed Oct 20, 2010 2:25 pm
thanks for the help
