Importing swf tour into Flash
annairam
by annairam » Mon Oct 18, 2010 11:55 am
Hi Everyone!
I desperately need some help! I know it is not flash forum but because it is about panorama swf I decided to ask you for help. I'm trying to insert panoramic swf (made in Autopano Tour) into my flash website. I'm using Flash CS3 and AS2. Is it possible that swf film is protected from import? After importing I can not see any content. I tried "load Movie" and other options to run the panorama but imported film is basically empty. I'm not very advanced user so I feel I little bit confused now.
I'm sorry if I repeat subject but I couldn't find any topic like that.
Thank you for your help.
Julia
by mediavets » Mon Oct 18, 2010 12:08 pm
Welcome to the forum...
See:
http://www.autopano.net/forum/p64212-2010-05-31-08-31-35/
You may also wish to post your question on the krpano forum:
http://krpano.com/forum/wbb/index.php?l=2
JohnM
by JohnM » Mon Oct 18, 2010 5:58 pm
Julia. Theres an example .fla in the krpano download. Loading in swf is not straightforward,
