Thumbnail ID
Marv
Thumbnail ID
by Marv » Sun Oct 10, 2010 5:53 pm
Beta 11:
On my Dig Project, I'm using side thumbnails of 8 pano views. When you open the tab containing the thumbnails and move the mouse cursor over each one... the file name pops up. Ok... great. But... now that I have hooked up tons of links and hotspots... the client want to change the names of the thumbnail pop-ups. How can I do that at this stage.
(Yes... I know... I should have been smart enough to figure out the correct simple file name when I created the Pano).
Marv.
Marv...
Nikon D700, Nikor 10.5mm DX (Shaved), Nikor 12-24mm DX, Modified Nodal NN180, Home made Nodal Ninja NN5 type Pano head, Really Right Stuff Plate & Clamps, Windows XP.
by mediavets » Sun Oct 10, 2010 8:01 pm
Marv wrote:Beta 11:
Marv.
Open the project - you did save it I hope? - and click on each pano image in turn and edit the Name in the Panorama Properties tab dialogue. Export the project again.
Done!
Marv
by Marv » Sun Oct 10, 2010 8:56 pm
Thanks Andrew,
I was hoping that's the way it would work.
Yes... I insanly save very often as Beta 11 crashes a lot on me. (1st program to do so).
Marv.
Marv...
