Playing a video in a tour - how?
frank007
Likes: 12 posts
by frank007 » Wed Oct 06, 2010 7:45 am
I was shown on Photokina an example that I can insert a video. for example in a living room there is a TV and there is running a tv-show.
As I can remember, I have to add a polygon around the TV screen and insert an objekt. But how can I do it that the TV is already on and showing a movie or tv show? I only found a possibility that I have to click on the TV and then the Movie is popping up.
I hope that you understand what I mean...
thank you and best regards
Frank
by mediavets » Wed Oct 06, 2010 8:32 am
frank007 wrote:I was shown on Photokina an example that I can insert a video. for example in a living room there is a TV and there is running a tv-show.
Frank
Draw a rectangular hotspot on the TV where you wisht to display the video.
Then select the video you wish to display in Hotspor Properties/Display/Object.
by klausesser » Wed Oct 06, 2010 11:09 am
mediavets wrote:Then select the video you wish to display in Hotspor Properties/Display/Object.
That´s great - but did you try it? The video is completely distorted - it fits into a polygon without proportional scaling . . and is turned 90°.
I didn´t find how to correct it.
Editing a rectangular or a polygon doesn´t let me delete it - usually i hit "ctrl" on a Mac and i can delete a hotspot.
by mediavets » Wed Oct 06, 2010 11:33 am
klausesser wrote:Editing a rectangular or a polygon doesn´t let me delete it - usually i hit "ctrl" on a Mac and i can delete a hotspot.
To delete hotspots - on Windows anyway:
1. In the project panel right-click on the hotspot and choose 'delete hotspot(s)' - see screenshot 1.
2. In the Hotspot Editor click on the 'Select' icon (leftmost) then right-click on the hotspot and choose 'delete hotspot(s)' - see screenshot 2.
by mediavets » Wed Oct 06, 2010 11:45 am
Errr... seems alright when I try it.
by klausesser » Wed Oct 06, 2010 12:10 pm
Hi Andrew!
Do you define a polygon or a rectangle?
by mediavets » Wed Oct 06, 2010 12:33 pm
klausesser wrote:Hi Andrew!
A rectangular hotspot.
You cannot specify a Display/Object file for a polygon hotspot.
by klausesser » Wed Oct 06, 2010 1:36 pm
mediavets wrote:You cannot specify a Display/Object file for a polygon hotspot.
Yep - didn´t think about that . . . (you can - but it´s . . it´s useless :cool: )
best to you, Klaus
by mediavets » Wed Oct 06, 2010 1:41 pm
best to you, Klaus
You can specify a Link/Object but not a Display/Object for polygon hotspots. The latter option doesn't exist for polygon hotspots, at least not in my Windows 32-bit APT V1.1 b11 nor PTP V1.5 b1 versions.
by klausesser » Wed Oct 06, 2010 5:04 pm
best to you, Klaus
Hi Andrew!
Surprisingly i worked in a polygon indeed. But was completely distorted. On my MacBook Pro it didn´t work in a rectangular shape - i´m just going to try it on my stationary MacPro. Will report my success (i hope) here.
P.S.: works great! :cool: Thanks again!
frank007
Likes: 12 posts
by frank007 » Wed Oct 06, 2010 5:17 pm
Thank you. I understood it. But you have to draw the rectangular shape clockwise, starting on the top left !!!
@Klaus: Wenn Du das Rechteck aufziehst, dann achte streng darauf, dass Du OBEN links anfà¤ngst, dann nach rechts oben, dann rechts unten, dann nach links. Dann schlieàŸen! Sonst wird es verkehrt gezeigt!
yves360
by yves360 » Sun Oct 17, 2010 11:37 am
It works now! Merci!
by klausesser » Sun Oct 17, 2010 1:55 pm
frank007 wrote:Thank you. I understood it. But you have to draw the rectangular shape clockwise, starting on the top left !!!
OHA!! Guter Hinweis!! :cool:
Auf DIE Idee, daàŸ das orientierungsmà¤àŸig für das Movie zusammenhà¤ngt bin ich noch nicht gekommen - ich mach das meist so, wie´s kommt.
Danke Dir!
GruàŸ, Klaus
