Extended Error save Message
by Marv » Sun Sep 26, 2010 12:53 am
I'm suddenly started getting the following Error msg when "Save project as extended" and all I did was add a hotspot and "Object" that I used many times in Beta 9. This is the first time I used it in Beta 11. When I check the files it creates the folder is missing 3 of the 8 panos that were there before I added the new hotspot Object.
It appears to render and play ok and everything appears to be there and work properly.
What's going on.
Nikon D700, Nikor 10.5mm DX (Shaved), Nikor 12-24mm DX, Modified Nodal NN180, Home made Nodal Ninja NN5 type Pano head, Really Right Stuff Plate & Clamps, Windows XP.
