ULR Link changes
Marv
ULR Link changes
by Marv » Fri Sep 24, 2010 9:23 pm
I'm running Beta 9:
I put the link in the URL and render and everything is fine. But if I save, close, and reopen APT and check the URL window... it has added the location of the file to the front of my URL. If I render... and try and excitute the link from the swf file the link fails (I think it also fails from the html file as well).
Am I doing something wrong?
Marv.
Marv...
Nikon D700, Nikor 10.5mm DX (Shaved), Nikor 12-24mm DX, Modified Nodal NN180, Home made Nodal Ninja NN5 type Pano head, Really Right Stuff Plate & Clamps, Windows XP.
by mediavets » Fri Sep 24, 2010 9:25 pm
Marv wrote:I'm running Beta 9:
Marv.
I think this bug was fixed in APT V1.1 beta 11 - see list of bug fixes:
http://www.autopano.net/forum/t9903-apt-1.1-beta-11
"* FIXED : html urls in spot properties displayed as a local file"
Marv
by Marv » Fri Sep 24, 2010 9:40 pm
Thanks Andrew... I knew you would say that.
I hate updating in the middle of a project... but if my current render goes ok, I'll be at a point to update.
thanks
Marv.
Marv...
