uploaded twice, published...says 'there is no video here'...   [SOLVED] - View the solution
42VR
Likes: 13 posts
by 42VR » Sat May 09, 2015 9:28 pm
i've tried uploading a 533 MB video 2x.
it is a Theta360 with soundtrack, MP4, right codec, etc.
i press publish.
it gets to processing.
then eventually says 'there is no video here'.
is it because it's Theta?
i published it to Youtube after using the Youtube metadata, and it works fine in Chrome.
the uploaded file to the Kolor gallery does not have the Youtube metadata processing.
it is the raw MP4 file.
this is my first 360 video upload test.
i'm sure i'm missing something?
thanks,
randy
Thomas L
Re: uploaded twice, published...says 'there is no video here  [SOLVED]
by Thomas L » Tue May 12, 2015 10:10 am
Some users already uploaded Theta360 videos successfully. Could you share us a link to your source video or your username if you didn't delete the video in the admin panel (via private message should you wish)?
