Hasselblad lenses on Nikon D700
spherorama
by spherorama » Sat Jan 16, 2010 5:33 pm
I recently bought an adapter to mount Zeiss lenses from my Hasselblad on my nikon D700. I bought it because I thought it was a pity to own all those wonderful lenses and hardly use them since I mostly shoot digital now. I did a test today and it looks promising. I used the Zeiss Sonnar 150mm F4.0 with a 40mm extension tube to take a panorama of a bouquet of flowers. The panorama is made out of 20 single shots and the original rendered picture came out 10809x9550 pixels. It's quite difficult to get the focus right with the Sonnar plus the extension tube, but I think for the first try the result is quite acceptable. If the weather is good enough tomorrow, I'll try to do some panorama shots outside.
Fuji Finepix S2. Fuji Finepix S5, Nikon D700, Pro Nikon D800, Novoflex Panohead VR System Pro, Samyang Fisheye 8mm shaved, Sigma 12-24mm, Nikkor 14-24 1:2,8 G ED, Nikon 35-70mm, Nikon 20 mm 1:2,8
Nikon 180mm 1:2,8, Nikon Macro 60 mm 1:2,8, Zeiss Hasselblad Tele Tessar 8/500 with adapter for Nikon, MK-PanoMachine 5.0 HS, GigaPan Epic Pro
120to120
by 120to120 » Sat Jan 16, 2010 10:03 pm
Gratulation spherorama, sehr schà¶ne Aufnahme.
Zeiss Sonar CF oder C Objektiv? Gibt es bitte Infos und ein Foto von dem Adapter?
Gut Licht, Jozef.
(*Merlin/Orion_BT - teleskop-austria.*); FTDI USB-TTL cable; Macbook (Intel) OS X10.5.6 / ext. Bluetooth Dongle_VIVANCO_B1002270209 / PW 2.1.20; Go-To / TA *Nokia N810 / PW 2.1.20 * Sony F717 / Sony R1 ; JJC SR-828; 15m Mast;
spherorama
by spherorama » Sun Jan 17, 2010 2:01 pm
Hi Josef,
it's a Sonnar CF lens. The next time I do a pano with this setup I'll take a picture for you. For more information on the adapter paelse follow this link: http://www.enjoyyourcamera.com/Objektive-Zubehoer/Objektivadapter/Nikon-Adapter/PRO-Hasselblad-Objektiv-Nikon-F-Adapter::188.html . This afternoon I did a new planar panorama of the same bouquet. This time the rendered image is composed out of 32 individual photographs. This time I used the live view function of the D700 and focusing has improved a little. The difficulty, however is to get the NPP correctly if you use an extension tube. But i shoot such macro panoramas only in rare cases. The picture posted is the result of my 2nd try.
120to120
by 120to120 » Sun Jan 17, 2010 3:56 pm
Hallo sperorama,
gewaltige Aufnahme. Steigerung wirklich sichtbar. Adapter interessant!
Hast du die 32 Aufnahmen mit Merlin gemacht? Welche Gerà¤te verwendest du?
spherorama
by spherorama » Sun Jan 17, 2010 7:33 pm
Hi Josef,
i use a Novoflex VR system pro. So you have to be careful not to miss a single shot.
spherorama
by spherorama » Mon Jan 18, 2010 10:04 am
I just tried to further optimize the panorama. Playing around with the APG settings I chose the Gigapixel option and the RMS improved from 8.5 to 3.5 without editing CP's. I changed the projection from planar to mercator and got this result. Some smaller ghosting in the lower left of the pano are due to a minor movement in the individual picture taken.
