Samyang
by mediavets » Mon Jan 25, 2010 6:01 pm
Adam wrote:Do you think that it is possible to do 4 around in portrait mode with this lens?
It is but the overlaps are small.
bigwade
by bigwade » Mon Jan 25, 2010 6:38 pm
Adam wrote:Here is hand held 6 images pano taken with Samyang. What do you think?
http://www.panoguide.com/forums/tipsntricks/7284/
spherorama
by spherorama » Tue Jan 26, 2010 9:16 am
It might be possible but you certainly need a nadir and a zenith shot. I processed your handheld panorama with cubic converter to show you the "black holes" that need to be filled.
Fuji Finepix S2. Fuji Finepix S5, Nikon D700, Pro Nikon D800, Novoflex Panohead VR System Pro, Samyang Fisheye 8mm shaved, Sigma 12-24mm, Nikkor 14-24 1:2,8 G ED, Nikon 35-70mm, Nikon 20 mm 1:2,8
Nikon 180mm 1:2,8, Nikon Macro 60 mm 1:2,8, Zeiss Hasselblad Tele Tessar 8/500 with adapter for Nikon, MK-PanoMachine 5.0 HS, GigaPan Epic Pro
by mediavets » Tue Jan 26, 2010 9:35 am
Yes, you will need a zenith shot (say at +60-65 degrees pitch), in addition to 4-around, for close to 360x180 coverage.
Screenshot below is of the nadir when shooting 4-around at -10 degrees pitch on a Canon cropped sensor body, usinha Noidal Ninja R-D3L rotator. You can see that the 'hole' at the nadir is quite small.
Adam
by Adam » Tue Jan 26, 2010 4:02 pm
Well, I don't know, if you have noticed, but the second house with columns is across the street and not a part of the first house with columns.
Where can I get "cubic converter"?
Thank you!
interested in panorama photography
Adam
by Adam » Tue Jan 26, 2010 4:08 pm
How was this nadir shot on NN? Can you attach shot of NN with camera on it?
Thanks!
Adam
by Adam » Tue Jan 26, 2010 8:19 pm
I was thinking to get digital level to help me to level my pano setups. However, it is magnetic and I am afraid of magnets effect on my camera. Can it spoil something in the camera, if it is placed very close to it?
http://www.amazon.com/exec/obidos/tg/detail/-/B001PTGBRQ/ref=pd_luc_mri?_encoding=UTF8&m=ATVPDKIKX0DER&v=glance
Thanks!
Paul
by Paul » Tue Jan 26, 2010 8:48 pm
OT, but if you are afraid of magnetic irritation you may have look on ebay item 270421788595
Paul
Adam
by Adam » Tue Jan 26, 2010 10:39 pm
Thank you Paul, but I want actual degrees readout. Otherwise, I can use bubble level.
I guess I will call manufacturer and ask, if magnets can be detached.
Adam
by Adam » Fri Jan 29, 2010 1:27 am
How did you shoot that Nadir?
I shot mine at -60-65 on NN5 in opposite direction and it is bigger than yours. Also, the view of a tripod similar to yours is visible only in SWF when played.
Can I upload it here?
by mediavets » Fri Jan 29, 2010 8:52 am
Adam wrote:
mediavets wrote:
spherorama wrote:It might be possible but you certainly need a nadir and a zenith shot. I processed your handheld panorama with cubic converter to show you the "black holes" that need to be filled.
I didn't shoot that pano, I don't have a Samyang FE lens myself, it was shot by 'Smooth' from panoguide.com.
I just wanted to show you that it is indeed possible to get 360x180 coverage shooting 4-around+Z+N with the Samyang FE on a Canon cropped sensor body, and I'm told the overlaps will be a little bigger with a Nikon DX cropped sensor body.
The image I posted was a screenshot when displaying the Flash VR of the pano.
The Canon APS-C cropped sensor is a different size from the Nikon DX cropped sensor. And the R-D3L rotator (excluding the leveller element) has a larger diameter footprint than the rest of the R-Dx range of rotators - 73mm for the R-D3L vs. 62mm for the R-D16/R-D8 vs. 54mm for the R-D4.
If you want a smaller nadir 'hole' just try pitching your camera/lens down a bit more for the main row. I don't know how far you can go before you find the 4-around no longer overlap with a 'zenith' shot and each other; or maybe that doesn't happen..
Adam
by Adam » Fri Jan 29, 2010 10:26 pm
Here is my nadir. Don't know what to do with it. spots are from fluorescent bulbs My son's room.
Comments
by mediavets » Fri Jan 29, 2010 11:03 pm
Adam wrote:Here is my nadir. Don't know what to do with it. spots are from fluorescent bulbs My son's room.
Comments
Errr... what do you want to do with it?
Adam
by Adam » Fri Jan 29, 2010 11:09 pm
I want get rid of tripod.
How?
by mediavets » Sat Jan 30, 2010 12:14 am
Adam wrote:I want get rid of tripod.
How?
Several options:
1. Leave it as it is but restrict the FOV in the Flash VR player so people viewing the pano cannot see the part of the pano with the tripod. This is simple with Pano2VR, and can be done with krpano but APT doesn't seem to offer a simple means of setting the viewing limits (yet?).
2. Cover the area of the tripod with another image - a so called nadir 'cap'; this could be a branding logo, or a mirror ball and so on. Pano2VR's patch tool offers a very simple way of adding a mirror ball. APT allows you to set a nadir 'cap' image.
3. Patch the tripod area at the nadir with another nadir shot taken without the tripod in view. This involves using an image editor that supports layers such as Photoshop. The patch tool in Pano2VR makes it much easier. This is a bit of a 'black art'; there are probably just about as many methods/techniques of doing this as there are people doing it.
Here's some more info about Pano2VR's patch tool:
http://gardengnomesoftware.com/tutorial.php?movid=09
Does this help?
spherorama
by spherorama » Sat Jan 30, 2010 4:05 pm
Adam,
there's no tripod. The mirror ball mentioned above is a nice option, that is quite easy to accomplish. I think this option is included in Pano2VR. But it can easily be done in Photoshop as well. You can apply text around the mirror ball with copyright information etc.
Adam
by Adam » Sat Jan 30, 2010 4:18 pm
Wow, how did you do that? Step by step please.
spherorama
by spherorama » Sat Jan 30, 2010 5:10 pm
Adam,
that one was easy. I just copied the left side of this wonderful carpet. This gave me a new layer after insertion of the copied piece. I mirrored it ant placed it over the tripod on the left side. I reduced the opacity of the layer, containing the copy of the carpet to 70% to place it correctly over the pattern of the background layer. I flattened the image and got only one layer. With the dodging and burning tools and the cloning brush I did final adjustments. That's all. It took less than 5 minutes to finish. I wish I always had jobs like that. Nice and easy going. But most of the time they aren't.
For the mirrorball you can find ready made actions to install in Photoshop. Example: http://wiki.panotools.org/Adding_a_nadir_cap_(mirror_ball) . Here is a tutorial how to create the mirror-ball http://www.nyfeler-mueller.ch/TripodCapText/TripodCapText.htm
Hope this helps Adam
Paul
by Paul » Sat Jan 30, 2010 5:31 pm
spherorama wrote:For the mirrorball you can find ready made actions to install in Photoshop. Example: http://wiki.panotools.org/Adding_a_nadir_cap_(mirror_ball)
:/ here is a working link to the pantools wiki: http://href.to/FOG
Paul
spherorama
by spherorama » Sat Jan 30, 2010 5:49 pm
Thanks Paul. I didn't realize that the link wasn't working. 4 eyes see more than only 2 :)
Adam
by Adam » Sat Jan 30, 2010 9:49 pm
spherorama wrote:Adam,
Thank you for your help.
The second example doesn't work, because I get this error (see attached). Where can I download latest pano tools from? Maybe that's my problem. My pano12.dll mybe bad.
by mediavets » Sun Jan 31, 2010 11:20 am
Adam wrote:Where can I download latest pano tools from? Maybe that's my problem. My pano12.dll mybe bad.
Is this what you are looking for?:
http://photocreations.ca/panotools/index.html
Adam
by Adam » Sun Jan 31, 2010 8:27 pm
The first one is pretty easy to do, but cannot figure out (yet) how to put text into nadir cap
spherorama
by spherorama » Tue Feb 02, 2010 9:55 am
Adam here is a little tutorial ti create a mirrorball and how to put text around it. First of all you have to have an equirectangular panorama having an exact aspic ratio of 2:1. Your example wasn't exactly 2:1, hence the black bar on the bottom half of your Panorama. Now open the panorama in PS. Apply a guideline that covers the tripod you want to cover with the mirrorball, in this case the black field (marked with two white arrows. Open a rectangular selection in the upper part of the picture. The selection should snap onto the guideline. Copy (strg+c) of the selected portion of the panorama. With strg+v you insert the copy on top of the panorama. Next select the transformation tool (strg+T) Grab the middle handle of the selection (yellow arrow) and bull it down to the very bottom of the picture. Next select the layers atirbut palette and apply a drop shadow to the active layer. Make sure you select an angle of -90° and make the necessary selections to have a big enough area to apply your text. Apply your text. Press strg+t again to transform the text. Shrink the text to 30% vertical. leave the horizontal dimension untouched at 100%. Flatten the image and make your QVTR movie with either APT or qubic converter.
That's all
etegration
by etegration » Wed Feb 03, 2010 8:08 pm
on full frame you can take 3 around to get a full 360, on crop, you most likely will need 4 images.
PreviousNext
