Can a spherical head also shoot cylindrical?
trondk
by trondk » Sat May 09, 2009 11:35 am
I am going to buy my first panohead. I want to shoot the occasional 360 derg. spherical, but also cylindrical ones.
If I get the Manfrotto 303SPH (my price area) can I also shoot cylindrical panoramas with this, or do I fx need a head like the Manfrotto 303? I already have the Manftroto 055XPROB + 488RC4.
What are some of your favorite combos?
Rgds,
Trond Kristiansen
Trond Kristiansen
Sony NEX-5, Rokinon 8mm fisheye, NN R1
Nikon D80, Nikkor 10.5mm fisheye, 18-135 kit lens, NN5L w/RD-16
iMac 24"; Macbook Pro 17"; APG and PTP
by mediavets » Sat May 09, 2009 11:46 am
Trond,
That Manfotto 303SPH head is clumsy, heavy and an ancient design.
I'd recommend that you consider a Nodal Ninja 3 or 5 series head (depending on which camera body/lenses combos you plan to use). The Nodal Ninja 5 with the R-D16 rotator is the most versatile.
What camera bodies and lenses do you have now?
Yes, a pano head used to shoot spehericals can be used to shoot cylindricals.
What sort of panos do you plan to shoot - interiors, landscapes,....?
What do you plan to do with the panos you create? Print them, display them on the Web,....
trondk
by trondk » Sat May 09, 2009 1:42 pm
Mediavets,
I have a Nikon D80 with the 18-135mm kit lens (...I want a new wide-angle,maybe the Tokina 10-16mm, but I want to get the panohead first). I will probably take more landscape panoramas, and I would love to put some prints on my walls.
http://www.flickr.com/photos/trondk/tags/panorama/
I will take a closer look at Nodalninja. It will be an import with taxes + customs + shipping etc :(
/trondk
Trond Kristiansen
by GURL » Sat May 09, 2009 2:31 pm
trondk wrote:Can a spherical head also shoot cylindrical?
Better cylindrical panos are possible when using a "spherical" two-axes pano head !
With both kinds of head the proper placement of the vertical axis enables the "center of the lens" (NPP) don't move when the camera is moved toward the left or the right. When using a "spherical" head, the additional horizontal axis enables the NPP don't move when the camera is moved up or down. Perfect single column (vertical) and multi-row panos can be shot (including giga-pixels mosaics with many rows and many colums). Spherical panos are just a particular kind of multi-row panos.
by mediavets » Sat May 09, 2009 2:50 pm
trondk wrote:Mediavets,
Did you mean the tokina 11-16mm wide angle or thge Tokina 10-17mm zoom fisheye?
Then IMO the Nodal Ninja 5 series would be most suitable because it can accommodate longer focal length lenses.
/trondk
Trond
In which of the Scanadinavian countries do you live?
Perhaps you would like to complete you Forum profile - click on your username next to a post...then we can offer advice more tailored to your location.
trondk
by trondk » Sat May 09, 2009 5:20 pm
Andrew,
The Tokina 11-16mm. The zoom fisheye looks like fun...
Norway (and I updated the profile)
/trondk
Trond Kristiansen
by mediavets » Sat May 09, 2009 6:11 pm
trondk wrote:Norway (and I updated the profile)
/trondk
Ah.... not a member of the EU - hence the concern about import duty etc when purchasing a pano head.
I guess there's no way around that?
If you are thinking mainly of shooting high res. partial panos of landscapes for print then you may well be interested in the Merlin/Papywizard robotic pano head - you could shoot 'the occasional spherical' with that too:
http://www.autopano.net/wiki-en/action/view/Orion_TeleTrack_altazimuth_tracking_mount
APP/APG V2 has special support for this robotic pano head.
John_Sauter
by John_Sauter » Sun May 10, 2009 10:47 am
trondk wrote:I am going to buy my first panohead. I want to shoot the occasional 360 derg. spherical, but also cylindrical ones.
Rgds,
Trond Kristiansen
I use the Manfrotto 303SPH, and I have no trouble with cylindrical panoramas. As others have noted, a cylindrical panorama is captured as a slice of a spherical panorama. AutoPano Pro has processing provisions for both cylindrical and spherical.
hankkarl
by hankkarl » Mon May 11, 2009 2:01 am
Take a look at
http://www.autopano.net/forum/t4895-kaidan-panoramic-heads
http://www.autopano.net/forum/t5653-mk-panohead-ii-version-2
And also look at the Merlin/Orion/Papywizard combo.
I hav ethe 303SPH, and have modified it. One issue is that it can't take a nadir shot that doesn't include the tripod and head, and the head makes a pretty large hole in the nadir. Its a bit wobbly even though its built like a tank in some areas. (the rails should be thicker and more rigid--depending on the weight of your camera, you can have a degree or so of roll). The "yaw" click stops are somewhat subtle, I'd like a more obvious "click".
But these are nitpicks, 303SPH does work well enough that I'm not going to replace it.
bigwade
by bigwade » Wed May 13, 2009 12:30 am
trondk wrote:The Tokina 11-16mm. The zoom fisheye looks like fun...
/trondk
Correct, the 10-17FE is fun.
But it's a remarkable lens, just for pano's
Think different.
With a NodalNinja 3 or 5 you can make wonderfull cylindrical pano's with this lens but also 180x360.
grtz!
Frank
trondk
by trondk » Sat May 16, 2009 7:56 pm
Thanks for all the input! I am looking at the NN3 with R-D3L 6-8-10 Rotator with built in EZ-Leveler-II. Why would I choose 6-8-10 rotator over the 6-8-30? More overlap with the 6-8-10 maybe.
Trond Kristiansen
by mediavets » Sat May 16, 2009 8:07 pm
trondk wrote:Thanks for all the input! I am looking at the NN3 with R-D3L 6-8-10 Rotator with built in EZ-Leveler-II. Why would I choose 6-8-10 rotator over the 6-8-30? More overlap with the 6-8-10 maybe.
I feel you be better off with the NN3 with R-D8 or R-D16, and better off still with the NN5 and R-D16.
trondk
by trondk » Sat May 16, 2009 10:09 pm
Possibly, yes but the shipping is + usd 150,- (chepest) + 25% taxes. There are no customs on photographic equipment as far as I could understand :-(
Trond Kristiansen
by mediavets » Sat May 16, 2009 10:25 pm
trondk wrote:Possibly, yes but the shipping is + usd 150,- (chepest) + 25% taxes. There are no customs on photographic equipment as far as I could understand :-(
Where are you planning to buy from?
trondk
by trondk » Mon May 18, 2009 1:58 pm
Andrew,
I got the Nodal Ninja 5L w/ RD16 Rotator. I am shipping it to Norway with JetCarrier.com, a mail and freight forwarding company.
Thanks for all the advice.
-Trond
Trond Kristiansen
by mediavets » Mon May 18, 2009 2:18 pm
trondk wrote:Andrew,
-Trond
I think you will be very pleased with it.
trondk
by trondk » Mon Jun 08, 2009 12:14 pm
Just a short note to inform you that the Nondal Ninja 5L arrived this weekend. Good quality and feel of the NN. I am hoping to adjust it to my lens tonight, and maybe shoot some midnight sun panormas. B-)
-Trond
Trond Kristiansen
