Anti-glare screen for Nokia tablet
DukeNukeIt
by DukeNukeIt » Sat Jan 17, 2009 4:03 pm
Hello everyone,
I've got my Nokia 800 already, but no Orion head yet. I was wondering if anyone has an issue with glare on the screen? Just trying to watch videos on the Nokia I've already noticed it's hard to see the screen sometimes. Are there any good anti-glare screen covers for the 800 series?
Also does the Nokia have a Contrast setting? All I've found is the brightness level...
Thanks,
Dave
by mediavets » Sat Jan 17, 2009 4:15 pm
Yes, glare can be an issue outdoors, just as it is with most LCD displays, although some are more reflective than others. The fashion these days seems to be for glossy highly reflective LCD screens on hadhelds and laptops.
You may wish to fabricate/improvise some sort of 'hood'/sunshield? A hard case with a hinged lid might do the trick? They say that some cases designed for the Nintendo DS-Lite (of which there are very many) also fit the N800 quite nicely but the Venom EVA DS-Lite case I bought was just too small. The Intec Dura Case for the DS-Lite seemed to be quite well liked by some.
You will find a lot of screen protectors around - you might check on Internet Tablet Talk forums to see which people like:
http://www.internettablettalk.com/
The Nokia Tablets do not have a contrast setting.
