Lens for Nikon D610
Bambalec
Liked in: 4 posts
Lens for Nikon D610
by Bambalec » Thu Jul 09, 2015 9:54 pm
So i finally decided to start with nikon d610 for my pano tour shooting. I would like to know your opinions about which lens i should go with? Im intrested in no taking more than 4 or 5 shots arround. Which fisheye lenses are able to do so? im worried that 15mm sigma or 16mm nikon are not enough for that... =(
Re: Lens for Nikon D610
by mediavets » Thu Jul 09, 2015 10:51 pm
Bambalec wrote:So i finally decided to start with nikon d610 for my pano tour shooting. I would like to know your opinions about which lens i should go with? Im interested in no taking more than 4 or 5 shots arround. Which fisheye lenses are able to do so? im worried that 15mm Sigma or 16mm nikon are not enough for that... =(
See: http://www.vrwave.com/panoramic-lens-database/
The Sigma 15mm and Nikon 16mm fisheye lenses require 6-around plus zenith and nadir to cover 360x180. But these are the best choices for the fullframe sensor D610.
A Sigma 8mm fisheye will require 3-around plus nadir but will 'waste' a lot of the fullframe sensor because the circular image in creates doesn't cover the entire sensor. It is not a good choice.
By the time you've setup to shoot a pano it takes little longer to shoot using 7 or 8 shooting positions rather than 4 or 5.
Bambalec likes this post.
Bambalec
Liked in: 4 posts
by Bambalec » Sat Jul 11, 2015 9:37 am
Thanks again :) But finally the question is which one of them 2 i should buy ...? anyone experienced a comparison in between them? Thanks in advance :)
