tripod?
itsrichphoto
Likes: 8 posts
Liked in: 5 posts
tripod?
by itsrichphoto » Wed Mar 18, 2015 2:52 am
Is there a tripod that has been specifically designed for shooting 360 sphericals? If the legs were less wide, but still stable, it would make the down view more visible without the need to patch the nadir point!
Re: tripod?
by Destiny » Wed Mar 18, 2015 3:35 am
I take it you have not tried out the transparent tripod yet.. :rolleyes:
AndyzArt likes this post.
itsrichphoto
Likes: 8 posts
Liked in: 5 posts
Re: tripod?
by itsrichphoto » Wed Mar 18, 2015 6:43 am
Did your mother never tell you there is no such thing as a stupid question? I have done 300 panos in the last week, I have to think of things that would make shooting more automated yet better... Don't you think it would be better if there was a tripod specially designed for the task underhand? I am surprised nobody has thought about it or capitalised on it before
Re: tripod?
by mediavets » Wed Mar 18, 2015 8:03 am
The Nodal Ninja nadir adapter was designed to assist with shooting nadir shots for easier nadir patching.
Do you have a Nodal Ninja pano head?
Tortuga
Likes: 3 posts
Re: tripod?
by Tortuga » Wed Mar 18, 2015 8:09 am
We offer especially for our MK PanoRing a tripod with long center column (50cm) and a small plate (3.2 cm) for the ring, the goal is the leveling ball between the legs => reduced nadir footprint :) .
MK PanoTripod - Made in Germany
http://www.vr-head.com
Best regards from Germany
Marc
itsrichphoto
Likes: 8 posts
Liked in: 5 posts
Re: tripod?
by itsrichphoto » Wed Apr 08, 2015 5:23 pm
I have been looking around! I met (i can't remember his name) at vrla and he had this!
http://freedom360.us/shop/f360-basic-ball-tripod/
It is ideally for 6x go pros. He also sells a stackable weight system with 3/8 screws to make monopods more bottom heavy.
There are also these
http://www.bhphotovideo.com/c/product/1 ... m/alsVwDtl
http://www.bhphotovideo.com/c/product/1 ... nopod.html
Re: tripod?
by klausesser » Wed Apr 08, 2015 6:25 pm
itsrichphoto wrote:Did your mother never tell you there is no such thing as a stupid question?
My mother always was and still is aware that there are silly questions indeed - so she tought me to be aware of them too . . =D :cool:
Here´s an example ;) :p :
itsrichphoto wrote:Don't you think it would be better if there was a tripod specially designed for the task underhand? I am surprised nobody has thought about it or capitalised on it before
Just give that a deeper thought . .
