Lens to Virtual Tour
vitoreis
by vitoreis » Fri Dec 06, 2013 12:55 pm
I have two cameras available: Pentax K-5 II (mine) and Nikon D7000 (from my brother). I've a virtual tour work to do in an restaurant with 8 panos. Will be my first work and I plan to invest in tools to get more work in the future. Software: Autopano Giga 3.0 and Panotour Pro 1.8 (2.0).
Que questions:
- Any of this cameras are good to do the job, right? And about lens? I just have prime lenses (50mm or 21mm) or legacy zooms. Thinking in using the Pentax and buy the Sigma EX 15mm f/2,8 DG Fisheye (here). Opinions?
Many thanks,
Vitor
Re: Lens to Virtual Tour
by mediavets » Fri Dec 06, 2013 2:00 pm
vitoreis wrote:Hello,
Que questions:
Many thanks,
Vitor
No problem with the cameras but that is the 'wrong' lens for cropped sensor bodies; the 15mm fisheye (FE) is intended for fullframe sensor bodies.
You should look to the Sigma 10mm f2.8 FE or the fully manual Samyang 8mm f3.5 for the Pentax K-5 II
Or Nikkor/Nikon 10.5mm FE or Samyang 8mm f3.5 with chip for Nikon 7000.
You'll also need a proper pano head - look at Nodal Ninja models, they are very popular and well designed and made.
And a good tripod.
vitoreis
by vitoreis » Tue Dec 10, 2013 1:28 pm
Que questions:
Many thanks,
Vitor
And a good tripod.
Thanks mediavets, i go to the Nikon 10.5mm FE!
by mediavets » Tue Dec 10, 2013 2:09 pm
Que questions:
Many thanks,
Vitor
And a good tripod.
OK, it's an excellent lens and relatively good value - although the Pentax offers more extensive AEB capabilities.
http://www.hdr-photography.com/aeb.html
by klausesser » Tue Dec 10, 2013 2:31 pm
mediavets wrote: - although the Pentax offers more extensive AEB capabilities.
Right - but if you need more bracketing features than Nikon provides: there´s PromoteControl.
Somewhat expensive, but extremely valuable.
I use it again since i switched from Canon 5D2 to Nikon D800. Unfortunately there´s
no MagicLantern for Nikons. Hope, this will change some day - the D800 is an extraordinary
fine camera for the money.
vitoreis
by vitoreis » Tue Dec 10, 2013 5:10 pm
mediavets wrote:OK, it's an excellent lens and relatively good value - although the Pentax offers more extensive AEB capabilities.
mediavets, can you elaborate? Because I choose this lens reading some opinions about the available lenses, but I feel that you telling that I can get some quality with the Pentax and (maybe) the Samyang 8mm?
Question is: as I'm starting with virtual tours now, I still don't know all the tricks about the technique associated with this type of photography. I presume that to get the best image quality I need to get the maximum EV range possible, correct? And then "join" as any HDR. Is that?
Many thanks,
Vitor
vitoreis
by vitoreis » Tue Dec 10, 2013 5:11 pm
klausesser wrote:Right - but if you need more bracketing features than Nikon provides: there´s PromoteControl.
Klaus, sorry for this question but what is PromoteControl?
Thanks,
Vitor
by mediavets » Tue Dec 10, 2013 5:46 pm
Thanks,
Vitor
This is: http://www.promotesystems.com/products/ ... ntrol.html
vitoreis
by vitoreis » Tue Dec 10, 2013 6:00 pm
Thanks, and about the upper question?
by mediavets » Tue Dec 10, 2013 6:11 pm
Many thanks,
Vitor
If you are planning to shoot interior panos and I think you are then it's often te case that the dynamic range presented by the scene exceeds the limits of a single exposure setting for all images in the pano, so people shoot bracketed exposures which they later combine with exposure fusion/HDR software either using APG's built-in capabilities or more often before stitching using third-partuy software.
However the dynamic range presented by many spherical scenes also exceeds the AEB capability of most cameras.
The Pentax has a more 'extensive' AEB capability than many other cameras including the D7000.
Amongst other features, the Promote Control allows a much more extensive bracketed exposures to be shot using cameras with more limited, or even no, AEB capability.
Has this answered your question?
by klausesser » Tue Dec 10, 2013 6:30 pm
Please let me add a note to what Andrew said already:
There are less expensive fisheyes than the Nikon 10,5mm.
But you should take in account to need SOME editing to get good images from them -
regarding CAs (chromatic abberations=red, green or blue rims on contrasty parts in the image)
or somewhat non-continuously behaving distortions or off-centering.
The 10,5mm Nikon FE isn´t the best of all fisheyes - but after some testing i found it´s very good
and definitely better than the cheaper ones. That´s my personal finding and opinion.
Another point is: avoid to "save shots). Using an 8mm circular fisheye you can save about two shots compared
to a 10,5mm fullframe fisheye on a DX camera.
But you loose more on image-quality than you win time-wise by saving two shots.
I guess your Pentax is a DX? The D7000 is one afaik.
So better use a fullframe-fisheye - 10,5mm fisheye on DX or a 15/16mm fisheye on FX. It pays in the end in terms of image-quality and zoomrange.
vitoreis
by vitoreis » Tue Dec 10, 2013 7:58 pm
Thanks both, mediavets and Klaus! Great help here!
Other question, not related with lens but about nodal ninja: there are a notorious price difference between Nodal Ninja 4 and Nodal Ninja 3. Any of you have experience with this two pano heads? The higher price of Ninja 4 is justified when we are working in field?
Regards,
Vitor
by mediavets » Tue Dec 10, 2013 8:39 pm
vitoreis wrote:Thanks both, mediavets and Klaus! Great help here!
Regards,
Vitor
I have a Nodal Ninja 4 with R-D16 rotator (and a 5L with standard/basic rotator, and a U-R10) but have never used a Nodal Ninja 3.
The NN4 is somewhat better engineered than the NN3 and has 15 degree locks increments on the pitch axis, which may be a slight advantage.
You may also wish to purchase the Nadir Adapter for either.
vitoreis
by vitoreis » Mon Dec 30, 2013 5:42 pm
Sorry for get back to this topic, you (and mediavets) give a great help but I'm find another option to use with my Pentax: SMC DA 10-17mm f/3.5-4.5 ED (€ 489). It's an 180-degree diagonal FOV. It's more comfortable to me if I can use my camera instead of asking to others - there are any real problem, just my preference.
I'm doing some tests with an wide angle lens (DA 21mm F3.2), 5 bracketing exposures per "angle" and get promising results. With the fisheye the process will be much more efficient!
Question is: can I get top results in terms of image quality with my Pentax (or with the new K-3)? If the nikon optics are really much better I'm considering to go to the Nikkor 10,5mm with a new 7100 attached insted of the K-3 :) Any of you know this DA 10-17mm?
Thanks again,
Vitor
by mediavets » Mon Dec 30, 2013 6:00 pm
vitoreis wrote:I'm find another option to use with my Pentax: SMC DA 10-17mm f/3.5-4.5 ED (€ 489). It's an 180-degree diagonal FOV. It's more comfortable to me if I can use my camera instead of asking to others - there are any real problem, just my preference.
Thanks again,
Vitor
You should be able to get good results with that and your Pentax, if you correct the CA, but this report also mentions a lot of purple fringing:
http://www.photozone.de/pentax/132-pent ... est-report
That lens is also sold with Tokina branding with either Canon or Nikon mounts.
vitoreis
by vitoreis » Mon Dec 30, 2013 9:08 pm
mediavets wrote:You should be able to get good results with that and your Pentax, if you correct the CA, but this report also mentions a lot of purple fringing:
Very bad results on that review =(
by klausesser » Mon Dec 30, 2013 9:38 pm
There are only very few real good fisheyes on the market. I suggest to stick with the brands which have long experiences in designing and producing good optics.
And here are Nikon and Canon dominant as long-time producers of very good fisheyes. The 2,8/16mm Nikon fisheye in my eyes is one of the best - and the Canon 2,8/15mm fisheye aso is excellent and i use it for about 5 years now (out of production, but you might find it for a good price still). The newer Canon 4/8-15mm fisheye i was told to be excellent - but somewhat expensive for a user who just needs it as a 15mm fullframe fisheye. I woudn´t buy it.
Regarding 1,5 crop in my eyes the Nikon 2,8/10,5mm fisheye is the best choice.
Basically i reject the use of circular fisheyes - 8 or 10,5mm on fullframe and 6 or 8mm on crop - because the massive loss on image-quality never can be justified by saving just two or three shots for a sphere. But that´s an individual choice of course.
by mediavets » Mon Dec 30, 2013 9:46 pm
Others have used it successfully - maybe it was poor example?
Anyway did you consider Sigma 10mm f2.8 FE lens for your Pentax?
vitoreis
by vitoreis » Mon Dec 30, 2013 9:56 pm
Yes, I read a small but interesting review of it:
http://www.ephotozine.com/article/sigma ... view-13543
But can find more opinions about it... Seems to be a valid option!
by mediavets » Mon Dec 30, 2013 10:00 pm
vitoreis wrote:Yes, I read a small but interesting review of it:
A few more opinions.
