Best technique for small spaces with a 5DMKiii
Liked in: 80 posts
by mediavets » Thu Apr 04, 2013 11:49 am
oreo5000 wrote:Would you guys reccomend PTgui over APG?
On a Kolor forum...I don't think so! :rolleyes:
You'd probably get a differnt answer if you asked the same question on the Panoguide forum where most members are PTGui users.
The difference between the two has been characterised as follows.
Autopano Pro and Giga are panorama stitching programs for photographers; PTGui is a panorama stitching program for engineers.
So choose whatever floats your boat...
oreo5000
by oreo5000 » Thu Apr 04, 2013 11:58 am
Ok, thanks I'm with you.
In APG do I simply throw all images in at once or should I be manually adding the zenith?
Is it better to feed APG the untouched RAW files over processed Tiffs/Jpegs?
aaronpriest
by aaronpriest » Thu Apr 04, 2013 12:05 pm
mediavets wrote:Autopano Pro and Giga are panorama stitching programs for photographers; PTGui is a panorama stitching program for engineers.
LOL! I'd have to agree I guess, I'm far more engineering minded. Hehe!
PTGui gives me better results with full spheres and ultrawide lenses (non-fisheye, full frame). AGP gives me better results with high resolution gigapans and color consistency. I use them both for different panoramas.
Likes: 3 posts
Liked in: 38 posts
by klausesser » Thu Apr 04, 2013 12:13 pm
I stated this about 6 years ago. But PTGui has changed a lot and meanwhile is as intuitive as AP.
But it`s more transparent in use and it´s definitely better documented . . . :cool:
Nevertheless i still prefer APG.
When you do commercial work i mean you need both apps.
I would compare it with PC and MacIntosh: i´m used to use Macs for almost 30 years now and i prefer them still.
But i added a PC beacause there are some few aspects in my way of working which a PC is preferable for me.
So i use BOTH "worlds" in parallel.
Likes: 3 posts
Liked in: 38 posts
by klausesser » Thu Apr 04, 2013 12:15 pm
oreo5000 wrote:In APG do I simply throw all images in at once or should I be manually adding the zenith?
No. The Zenith is in the sphere. What you must shoot and add or retouch it seperately is the Nadir.
oreo5000
by oreo5000 » Thu Apr 04, 2013 12:31 pm
Sorry Klaus I'm not sure I follow.
Correct me if I'm wrong but the Nadir is the below, i.e. the floor, and the zentith is above, i.e. the ceiling.
I'm shooting 6 vertical frames with the camera looking down 12 deg. and a seperate frame for the Zenith.
So I end up with 7 files
Likes: 3 posts
Liked in: 38 posts
by klausesser » Thu Apr 04, 2013 12:45 pm
oreo5000 wrote:Sorry Klaus I'm not sure I follow.
Right!
PS: i don´t call the Zenith-shot an "extra" shot because it´s done the one shooting with the other 6.
Whereas the Nadir is an "extra" shot because you must reorganize the head/camera in an extra way.
So i see it as an "extra" shot compared to the Zenith, where you just tilt the camera on the head
without any re-adjusting the whole setup.
oreo5000
by oreo5000 » Thu Apr 04, 2013 12:50 pm
So my question was.. ;)
Do I simply drop all 7 files into APG at once?
Likes: 3 posts
Liked in: 38 posts
by klausesser » Thu Apr 04, 2013 12:55 pm
oreo5000 wrote:So my question was.. ;)
As i said: yes!
:cool:
as an example - i used 6+Z wà­th a 5D2 and 2,8/15mm fisheye here: http://360impressions.de/Wohnung/
Nadir wasn´t shot extra but was retouched. No client cares about an absolutely perfect or not Nadir as long as it is not too obviously recognizable as an error.
Only pixelpeeper like to do that - but they´re not clients . . :cool:
oreo5000
by oreo5000 » Thu Apr 04, 2013 2:06 pm
Thanks Klaus,
That looks great, can't spot any problems there. I still seem to be getting a bit of a vertical break even though I have the nodal point pretty much spot on. Any ideas what I can try to resolve this?
Another strange thing is that when I stitch the images with APG and then place the outputted file into Pano2VR the resulting 360 looks a little warped and I cannot look up or down. If I stitch it with PTgui and drop that outputted file into Pano2VR then I dont have any issues and I can look up and down and the only problem I see is small Nadir hole.
Any ideas?
Thanks again, really appreciate everyones quick responses
Likes: 3 posts
Liked in: 38 posts
by klausesser » Thu Apr 04, 2013 2:35 pm
oreo5000 wrote:Any ideas what I can try to resolve this?
Yes: "try harder" . . ;):cool:
HansKeesom
by HansKeesom » Thu Apr 04, 2013 5:26 pm
oreo5000 wrote:Thanks, I'll stick with that then.
Depends. I think PTGUI sometimes wins when it comes to mage-quality, but when you have to process multiple panoramas (like 5-10) APG really shines. Also easy of use right out of the box I like APG much more. I have a license for both programms but somehow APG makes it easier for me to keep track of what is happening.
Regards, Hans Keesom
HansKeesom
by HansKeesom » Thu Apr 04, 2013 5:27 pm
oreo5000 wrote:Thanks Klaus,
Any ideas?
Allow me to stitch them and I will tell you what I find.
HansKeesom
by HansKeesom » Thu Apr 04, 2013 5:35 pm
oreo5000 wrote:Just noticed also that -12 deg results in part of my NN5 arm being visible in the lower right of the frame. Will this cause a problem at all?
No as it will be projected to a part of the resulting panorama where other parts of other photos will also projected on. In a kind of democratic process it is then concluded that the black part is only visible on one photo therefore can be removed. And if this is not done automaticly you can mark the black part with a red marker. If then still it won't go it means there was not alternative imageinformation for that part
oreo5000
by oreo5000 » Thu Apr 04, 2013 5:38 pm
Thanks, doesnt seem to be an issue so I dont think I'll need to mask
Do you guys know what these pano's were created with? or is it something custom
http://www.eyerevolution.co.uk/?gclid=CIGP56SusbYCFYfJtAod8kgAPA
Likes: 3 posts
Liked in: 38 posts
by klausesser » Thu Apr 04, 2013 7:24 pm
oreo5000 wrote:Thanks, doesnt seem to be an issue so I dont think I'll need to mask
KRPano.
oreo5000
by oreo5000 » Fri Apr 05, 2013 9:52 am
Likes: 3 posts
Liked in: 38 posts
by klausesser » Fri Apr 05, 2013 11:39 am
oreo5000 wrote:Cheers Klaus,
And this one? KRPano also? http://www.eyerevolution.co.uk/virtual_tours/car-360-panorama/
I don´t think so.
HansKeesom
by HansKeesom » Sat Apr 06, 2013 7:27 pm
HansKeesom wrote:....... I will do a test coming weekend with a shooting pattern that is an extension of what we use for fisheye lenses. Theory is that by extending the method we use for fisheye lenses, it will deliver good results also for 35, 50 and maybe even 85 mm for a sphere. The weekend begins coming friday!
Test done with a 50 mm lens on a canon 40 D (1.5 factor! Should be easer with a 5D). Had to take 242 photos for full 360 * 180. Detection went very, very easy . Editing in APG to get rid of tripod took about 5-10 minutes using markers. Very nice nadir as result without photoshopping. I will try to do 85 MM tests ASAP and show results here. Hope to do it final test in small room with texture/graphics on the floor to prove nadir is really working. So far looking good.
Likes: 3 posts
Liked in: 38 posts
by klausesser » Sat Apr 06, 2013 8:15 pm
HansKeesom wrote:Editing in APG to get rid of tripod took about 5-10 minutes using markers.
How long does it take to do the additional Nadir-shoot? 5min i guess. So we have about 10-15min.
Doesn´t take longer with retouching.
What when you need to shoot a second, identical sphere? What when you need to use a motorized head?
What about the xml then?
PS: btw. - would you mind showing the result?
HansKeesom
by HansKeesom » Sat Apr 06, 2013 9:09 pm
When there is a pattern on the floor like a logo, can you do that with retouching? Seem to me you copy something into the nadir that is not exactly what was actually there.
a second identical sphere? why, how what?
xml? Why? I have my pattern written down on paper and APG had no problem detecting it, even though there was a white wall.
Making the nadir shots took 3 minutes. So total work problably closer to 10 minutes.
You don't NEED to use a motorised head! You CHOOSE to use a motorised head or not. If I would, I would go for the moonslide, which is the only motorized head I know that can make nadir shots http://www.marc-kairies.de/english/mk-panomachine-moonslide/index.html examples have perfect nadir.
Test was done indoors in a rather messy living room. Rather not show that. As I said, I want to do a test in a more convincing situation. hope to show that, though I am not sure if anyone will be convinced by that either.
At the same time, I don't think I can nor care about convincing people. When it works for me and the people I work with, that is good enough
aaronpriest
by aaronpriest » Sat Apr 06, 2013 10:46 pm
This weekend I'm stitching a virtual tour of a house that I shot yesterday for a prominent home builder. I shot my nadirs slightly off-axis with the Panoneed manually after moving the tripod. I'm stitching with PTGui Pro and using its viewpoint correction feature to mask in the nadir. I tried cloning in Photoshop but with these precise floor patterns, color variations, and glare from various light sources, it just was not possible. I load in all the files from the .xml and apply it to get my regular sphere, set a few vertical line control points to make sure things are precisely level, and then load the nadir shots and set a few manual control points to align it, then mask out the tripod areas. Works very quickly and efficiently. I'm not sure how to do the same with APG, but I look forward to any tutorials. I've used PTGui for a very long time and I'm used to its many quirks, I can't say the same with APG yet.
Here's a good tutorial on PTGui Pro's viewpoint correction: http://www.johnhpanos.com/ptgvpt.htm
HansKeesom
by HansKeesom » Sat Apr 06, 2013 11:08 pm
Hi Aaron,
You are welcome to send me the photos of one panorama so I can see what I can make of it and what tips I have for you.
aaronpriest
by aaronpriest » Sun Apr 07, 2013 12:20 am
These are commercial ones for a client, and I can't (or shouldn't) publicize them until they have reviewed the final product. I can find a similar project to send your way in a couple days when I'm done with this one though if you'd like. I'm dumping all 234 photos or so (9 brackets) into PTGui and letting it handle the exposure fusion because it's doing it so well and it saves time doing it all in one step over an extra step blending the brackets first. They render in just a couple minutes on this machine. But it's very hands-on in PTGui creating a few vertical lines for leveling, masking out the tripod, manually aligning the off-axis nadir with the viewpoint correction feature, etc. My time in Photoshop is minimal though afterward, basically just removing some cosmetic blemishes like dust on the floor. I cleaned my sensor and lenses before the shoot (I always do on a major one), so no dust spots to deal with. And the house was professionally cleaned the day before too; so very, very little Photoshop work on this project. :D
HansKeesom
by HansKeesom » Sun Apr 07, 2013 12:48 am
aaronpriest wrote:These are commercial ones for a client, and I can't (or shouldn't) publicize them until they have reviewed the final product. I can find a similar project to send your way in a couple days when I'm done with this one though if you'd like. I'm dumping all 234 photos or so (9 brackets) into PTGui and letting it handle the exposure fusion because it's doing it so well and it saves time doing it all in one step over an extra step blending the brackets first. They render in just a couple minutes on this machine. But it's very hands-on in PTGui creating a few vertical lines for leveling, masking out the tripod, manually aligning the off-axis nadir with the viewpoint correction feature, etc. My time in Photoshop is minimal though afterward, basically just removing some cosmetic blemishes like dust on the floor. I cleaned my sensor and lenses before the shoot (I always do on a major one), so no dust spots to deal with. And the house was professionally cleaned the day before too; so very, very little Photoshop work on this project. :D
no need to publish them, send me a link to me on hans@hanskeesom.com or send me an email adres so I can share you some space on dropbox.
PreviousNext
Return to Hardware
