Page 1 of 1
Hardware recommendation
PostPosted: Thu Nov 15, 2012 11:49 am
by videopixel
We are a real estate company that want to start with 360° tours. We have already a Nikon D800 with 14-24mm lens and tripod. What kind of system would you recommend for motorized head?
thx
PostPosted: Thu Nov 15, 2012 12:05 pm
by klausesser
videopixel wrote:We are a real estate company that want to start with 360° tours. We have already a Nikon D800 with 14-24mm lens and tripod. What kind of system would you recommend for motorized head?
thx
Depends on how much money you´re willing to spend and what featurs you definitely need. The cheapest solution would be a Merlin for around 500.-€ completely up to Panoneed, Seitz and Rodeon for around 2000.- to 4000/5000.- €.
For indoors the Merlin isn´t preferable becaus of it´s big base - the other heads produce only very small Nadir-holes which are easy to fix doing an extra Nadir shot or being retouched in minutes.
To be honest: for real estate indoors i´d suggest a good manual head and a fisheye. This way you only need 5-7 shots for covering a sphere. Your 14-24mm lens is a fine beast - but not ideal for doing spherical panos.
PostPosted: Thu Nov 15, 2012 12:46 pm
by videopixel
Thanks Klaus,
So with a AF Fisheye-Nikkor 16mm f/2.8D and a good manual head it would be the best option...
