neutralhazer limits
jl-kol
neutralhazer limits
by jl-kol » Sun Apr 29, 2012 2:19 pm
Yesterday I bought the new neutralhazer plugin.
The examples are very impressive but I think you should publish a size limit for files.
When I attempt to process a large 16b rgb tiff or pshop file it simply gives up with a 'not enough memory' message (1).
My Mac Pro has 32GB of memo of which 28GB was assigned (after several tests) to Photoshop & no other software was open. File size 19652 x 9826 x 300 - 1.16GB in size. I can process about 1/3rd of the image (2) but not all of it. What are the size limits of this filter?
Regards
JL
jl-kol
by jl-kol » Sun Apr 29, 2012 6:55 pm
ps
By cutting up the image I managed to neutralhazer the two halves then, with some clone stamp work, put them back together again.
NH is an excellent tool but it does need to be able to handle large files!
Regards
JL
