sampl imagess from Nikon D800E
by klausesser » Thu Mar 08, 2012 2:50 am
Hi!
I saw some sample images from te Nikon D800E (without AA-Filter).
Absolutely great for the price!! I ws absolutely surprised (see image 2)
http://imaging.nikon.com/lineup/dslr/d800/sample02.htm
In terms of stitiching 36Mpx mean lesser shots or deeper zooms - MUCH deeper zooms with the same amount of images.
What you need an 85mm before you can now do with a 50mm/lesser images and have a comparable zoom-factor or you do the same amout of images with 85mm
but have a far deeper zoom . . . :cool:
That´s great - the image quallity is outstanding for FX.
by gkaefer » Thu Mar 08, 2012 12:53 pm
and the moiree?
so could you compare the "less" sharpness from the D800?
i mean for panos: is the possible negative moiree effect you could have worth the more sharpness of the D800E?
(PS: no moiree on the images...)
lg
by klausesser » Thu Mar 08, 2012 2:00 pm
gkaefer wrote:and the moiree?
lg
Hi Georg!
My experiences with MF-backs without AA filter and Leica is: moiree comes rarely. IF it´s there you can comomensate it locally without having to treat the whole image.
Draw a selection around the area where moiree is and use a filter to compensate it (CaptureOne, Phocus, Photoshop as examples) work well.
Of course you loose a bit resolution - but you can select the area where you loose it.
Fine geometrical structures in fabrics or metal-woven objects are sensitive to moiree. Most motives are not.
Look on the Nikon site and compare the D800 images to the D800 images.
I definitely would prefer the D800E for "normal photography. It would be interesting to test a D800E for stitching with APG . . . because APG might react to moiree in a rather complex way :P:cool:
So: if you´re willing to do ANY effort to optimise images for stitching (like i use to do) treating moirees with selective compensation is the way to go.
But as i said: moiree isn´t always visible.
In the end it´s not sharpness - it´s simply the more natural look of details in D800E images which attracts me :cool:
