Suggestion on panohead
by klausesser » Tue Nov 30, 2010 10:47 pm
PanoMachine wrote:
Alexandre also agreed to implement a more generic Import wizard/filter for any regular grid/mosaic image set, which woudl also accommodate images shot with the camera in a  vertical orientation and using pateres other than those supported for /by Giagpan heads. Such a generic Import Wizard/filter would be fine for use with Panomachine image sets without that optional lone zenith image.
Yes, that will be a good way!
However I´ll look to improve the MK PanoMachine, too.
Have a nice time
Marc
Hi Marc!
That´s very interesting! Because the Panomachine´s technical skills are obvious: it´s accurate AND fast.
Of course such a device can´t be done in the Merlin´s price range.
best regards, Klaus
PanoMachine
by PanoMachine » Wed Dec 01, 2010 7:55 am
Hi:
First I´ll send the exact workflow to Alexander Jenny :)
And I´ll look to papywizard :cool:
To improve the MK PanoMachine is every day on my board.
Thanks all for the good advices!
Best regards
Marc
tived
by tived » Wed Dec 01, 2010 11:12 am
Hi Marc
You have already in the past year made progress with you Mk PanoMachine, by listening to people requests, such as adding the vertical rotor to your kit.
I just wished I had the funds!
keep it up
Henrik
PanoMachine
by PanoMachine » Wed Dec 01, 2010 12:50 pm
Hi Henrik:
We want to provide us with more exciting ideas for the future and you have the money to buy...
Hope to hear from you in the future
Marc
Marv
by Marv » Thu Dec 23, 2010 9:36 pm
So... What's the bottom line as we speak?
I'm trying to digest all this and I"m thinking about going with MK Pano Machine or Panogear.
I'm looking at a system for 360x180 panos, HDR, and good xml type import (that really works... I've had problems with sky sometimes).
Marv.
Marv...
Nikon D700, Nikor 10.5mm DX (Shaved), Nikor 12-24mm DX, Modified Nodal NN180, Home made Nodal Ninja NN5 type Pano head, Really Right Stuff Plate & Clamps, Windows XP.
Marv
by Marv » Thu Dec 23, 2010 11:46 pm
So what is the bottom line?
I'm looking at getting maybe a "MK Pano Machine" or "Panogear". I need HDR, and prefer wireless, and xml papyizard files (for stiching sky or plain areas).
Marv...
by mediavets » Fri Dec 24, 2010 11:11 am
Marv wrote:So... What's the bottom line as we speak?
Marv.
I believe you plan to use a Nikon D700 body? Is that correct?
This is quite a large DSLR and if you want to mount it at the NPP for 360x180 panos you will have to modify the crown/dovetail clamp on a Merlin/Panogear head.
If money is no object then you might consider the Clauss Rodeon VR robotic head which will more readily accommodate large DSLRs and for which an Import wizard/filter exists to assist with the placement of 'featureless' images:
http://www.dr-clauss.de/Panoramicphotography_EN.htm
What sort of lens/lenses are you planning use on the D700 when shooting 360x180 panos on a robotic head?
by mediavets » Fri Dec 24, 2010 11:16 am
Marv.
If money is no object then you might consider the Clauss Rodeon VR robotic head which will more readily accommodate large DSLRs and for which an Autopano Giga Import wizard/filter exists to assist with the placement of 'featureless' images:
Marv
by Marv » Fri Jan 21, 2011 12:04 am
marco.lanciani wrote:Need something to work remotely... that does hdr, at least 5 or 7 shots by 2EVs.
The camera will be a D700+50mm
How do you plan to get the D700 to do HDR by 2EV's?
Best I can get is 1EV.
Marv...
by gkaefer » Fri Jan 21, 2011 12:22 am
the promote control can handle the D700
http://www.promotesystems.com/products/Promote-Control.html
Marv
by Marv » Fri Jan 21, 2011 12:32 am
Great... thanks, Georg.
Marv...
Previous
