3D Video, right eye output white screen only
panoguy
by panoguy » Fri Nov 13, 2015 5:52 pm
I was happy to see the announcement of the new 2.3 beta version, have installed it and immediately I was impressed by the improved performance.
After checking the output file, I see only one frame at the beginning of the video, the rest of the footage is white. Audio is there but the screen is pure white till the end of the video.
The same thing happens with a new project, even the preview does not work, after advancing the realtime preview by 4 frames I see only the white output!
I'm using Windows 10,
Intel(R) Core(TM) i7-4770K CPU @ 4.20GHz
GeForce GTX 980/PCIe/SSE2
Asynchronous
Statistics :
Total time : 3 min:40 s
FPS : 8.151
Decoding : 35 %
Rendering : 23 %
Encoding : 70 %
After checking it with Win 7, same behavior but now I just found out that the white output is only one the right eye, the left eye looks fine.
See the new screen shot.
Normal scene: Light is on, left eye is fine, right eye totally overexposed
Shutting down the light:
All other scenes with additional brightness causes the right eye to end up in a white screen.
Please get this fixed asap ;-)
martin.arnoux
Liked in: 27 posts
Re: 3D Video, right eye output white screen only
by martin.arnoux » Mon Nov 16, 2015 9:27 am
Thank you for this report.
We are working on it. For now you can render the left and right videos separately and merge them in a third party software.
Sorry for the inconvenience,
Martin
ClaireM
Liked in: 36 posts
by ClaireM » Mon Nov 16, 2015 3:59 pm
This has been fixed and it is going to be released in the next beta.
(ISSUE 5328)
Best,
Claire
panoguy
by panoguy » Mon Nov 16, 2015 4:25 pm
Great news Claire, Thank you
can you give me some time-line when the next beta will be available?
I have a very large project 1.8Tb of data needs to be stitched ;-)
martin.arnoux
Liked in: 27 posts
by martin.arnoux » Tue Nov 17, 2015 2:08 pm
We can not give you a timeline for that, sorry. But for a professional project you shouldn't use a beta version.
Cheers,
Martin
