Colors mismatch despite equal settings
jschrader
Liked in: 3 posts
by jschrader » Tue Dec 15, 2015 5:39 pm
The background colors of Classic control bar and classic thumbnails bar do not match.
In my example the values are set to 222 for color and 204 for transparency. In both plugins.
On the screen they do not match.
When the values are set to 255 and 255 in each plugin they both match.
Besides that you still do not use correct transparency settings.
At 255 all colors should be opaque which here they are not.
Re: Colors mismatch despite equal settings
by Destiny » Tue Dec 15, 2015 10:31 pm
Hi... Yes, this has been mentioned before.. This issue arises from the fact that the two graphics do not start out the same..
jschrader
Liked in: 3 posts
by jschrader » Wed Dec 16, 2015 10:10 am
Ah, good to know that not all betatesters are sleeping :-))
What is the meaning of "do not start out the same"?
When I have a two true whites and reduce for both the same amount of alpha and saturation there should be little room for interpretation, especially for a machine, hehe :-)
by Destiny » Wed Dec 16, 2015 10:32 am
I will try to find that old post which explains more.. I remember that the two graphics have different value in the System Library from the beginning.. I do not know why.. It causes a mismatch of colours but its really the alpha value. I think thats what it was.. I just remember a post about this a long time ago.. I might have even been the one that crated the post..
jschrader
Liked in: 3 posts
by jschrader » Wed Dec 16, 2015 12:13 pm
Long time ago, and it's still not fixed in the RC?
Tststs, seems I need to have a word with Alexandre again :-)
But no, the improvement PTP has made is much appreciated, and if it's knowingly coming from the alpha value I could try&error to find the right match, although a bit clumsy.
by benji33 » Mon Dec 28, 2015 11:18 am
Yes the alpha setting is wrong on the control bar alpha is applied on the image ressource and also on the layer.
Will be corrected.
About opacity, the Classic items are transparent by default so it's not possible to set a real alpha 255 (1.0) on them.
The 255 value is the highest opacity only, but not the full opacity of the layer.
It's ambiguous I know.
