FoV Toggle plugin
Xander Berkenhagen
Liked in: 8 posts
FoV Toggle plugin
by Xander Berkenhagen » Wed Oct 28, 2015 5:51 pm
Hi Guys,
Is it possible to add to the FoV toggle plugin a between range?
Like if fov is between 40 and 45 degrees then do something?
Then we could use it for focussing on different parts of the pano and show stuff..
Regards,
Xander Berkenhagen
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: FoV Toggle plugin
by Cliquetsy » Wed Oct 28, 2015 6:33 pm
Have a look at maybe building the tour twice (one with the action after 40° and the other before 45° and backing up the xml between builds) to the append the two?
Xander Berkenhagen
Liked in: 8 posts
by Xander Berkenhagen » Wed Oct 28, 2015 11:11 pm
I don't think that is going to work... And a lot of work if you need to change a lot.
