Web VR Hotspots & Navigation   [SOLVED] - View the solution
mjaszo
Liked in: 3 posts
by mjaszo » Thu Aug 06, 2015 1:41 pm
I have set of panos, 1st one is loaded. I can see small cross in the middle. How do I change the panos?
edit:
So th eoptions are gazing for smartphones and PgUp/Down with the keyboard? No "next/prev pano" etc.?
Liked in: 440 posts
Re: Web VR
by Annis » Thu Aug 06, 2015 2:37 pm
The only way to navigate is using navigational hotspots.
Everything else is removed in VR Mode.
mjaszo
Liked in: 3 posts
Re: Web VR
by mjaszo » Thu Aug 06, 2015 2:43 pm
OK. Thanks for the help!
And for all updates. VR looks really cool. My #1 favourite is finally changing the panos order in the project in the proper way :)
mjaszo
Liked in: 3 posts
Re: Web VR
by mjaszo » Wed Aug 19, 2015 2:02 pm
Another thing: I'd like to add bunch of hotspots in nadir for VR only. I don't want it to be visible on PC and tablets, mobiles (for cardboard etc.) only. How do I do that in PTP (if possible) or in which file do I change the code and how?
Likes: 60 posts
Liked in: 169 posts
Re: Web VR
by benji33 » Thu Aug 20, 2015 8:34 am
VR only hotspot doesn't exist. Must be added manually into xml.
mjaszo
Liked in: 3 posts
Re: Web VR
by mjaszo » Thu Aug 20, 2015 10:17 am
OK. Which function triggers hiding of VT elements (and could be used for showing additional hotsposts in nadir)?
Should I add hotspots the same way vrcursor is added: <hotspot name="vr_cursor" keep="true" vr="true"
or as typical hotspot with additional desktop/mobile=false; vr=true or similar?
Cliquetsy
Likes: 105 posts
Liked in: 119 posts
Re: Web VR  [SOLVED]
by Cliquetsy » Thu Aug 20, 2015 11:01 am
How about (this is just an idea),
-you duplicate the kpt and cache (new name, whatever)
-open it
-remove all your current hotspots and create your nadir nav hotspots
-build in the same folder with same name as your original tour. You'll now have _VR.xml versions that have your nadir hotspots.
-backup all the _VR.xml files in a new folder or your desktop or wherever you want
- open the original project back up
-build it again to get the original hotspots and everything back
-replace all the _VR.xml files by the duplicate projects ones.
You'd have to do this once you've finished creating the project to avoiding the risk of building over the files, but I think this could work.
Just make sure you don't change any names or anything, other than the hotspots the tours have to be identical.
mjaszo
Liked in: 3 posts
Re: Web VR
by mjaszo » Thu Aug 20, 2015 11:33 am
Sounds OK when what's in VR mode is in VR files. Is it like that? When I add hotspots in PTP they are considered for PC-VT and VR-VT separately? I'll give it a try. :)
EDIT: Looks like it's working! I've prepared 2 tours with "PC" and "VR" navigations and overwritten _vr files.
Thanks a lot, Cliquetsy! :D
Cliquetsy
Likes: 105 posts
Liked in: 119 posts
Re: Web VR
by Cliquetsy » Thu Aug 20, 2015 1:24 pm
Yes the vr.xml files are the ones that are used when you're in VR mode.
Glad it worked :)
http://www.kolor.com/wiki-en/action/vie ... rtual_Tour
mjaszo
Liked in: 3 posts
Re: Web VR
by mjaszo » Thu Aug 20, 2015 1:25 pm
Thanks for the link, I couldn't find it. :)
